10-26-2019, 11:54 PM | #1 |
Rep 1,255
i drive turned red while driving, wont turn on
idrive randomly turned red/orange while driving, i pressed dvd eject to take out the dvd i was watching (dvd in motion) and it turned off completely and my speaker went down
i tried holding the volume/power button down for 30 seconds and letting go, didnt work. i tried holding power and eject button at same time, nothing i disconnected battery and waited 30 minutes, reconnected, didnt work car runs fine, just no idrive/music/anything. wtf can this be? 2013 m6 vert. |
10-27-2019, 10:27 AM | #2 | |
Rep 7,489
Make sure the START button is pressed (without foot on brake...engine NOT running). Then follow the instruction below where it says to press & hold the VOL button for at least 25 seconds. I'd also pull up the main MENU screen just to be on the safe side. See paragraph that red arrow is pointing to in pic below from the TIS:
10-27-2019, 03:56 PM | #3 | |
Rep 1,255
10-28-2019, 04:19 AM | #6 | |
Rep 1,255
ive been reading that its this 61119185171 part number, which needs to be replaced. but i cant find how to get to it anywhere in a DIY |
10-28-2019, 02:06 PM | #7 |
Rep 318
can you scan the car with ista? i see your having issues with the cic and i wouldnt be suprised if it is causing other parts to not work as it is the information hub in the car. but based off the power down and restart i would suspect it is either the cic unit itself is failing, or the quadlock connector is loose.
10-31-2019, 08:11 AM | #9 | |
Rep 318
Regardless nice find! |
10-31-2019, 11:40 PM | #10 | ||||||
Rep 1,255
i went 2-3 days without it crashing. 2-3 days without using a dvd, and it didnt crash, i assumed it was fixed. today, driving 10 mph, no dvd in tray for 3 days, and out of nowhere i get this screen again for 20 seconds before it goes dark my HUD also crashed..until it restarted 30 min later, only to die immediately again, now my idrive is dead but my HUD is active. i have alot of codes.. Central Gateway Module codes Quote:
I cant find SHIT on most of these codes |
11-01-2019, 04:24 AM | #11 |
Rep 1,255
11-01-2019, 08:36 AM | #12 |
Rep 318
contact bimmer-tech.net for deeper assitance with that. i would say the head unit died imo. the zgw and cgw still appear to be responding. i bet the fiber optic port is dying in the head unit. that is the loss in lock missing. having dealt with fiber optic systems before typically losing lock is data bit stream errors. or loss of reference clock. for the screen to display i would say the power cable is good, the display cable is also probably good, since with no input the screen turns off. its probably easy to say just replace the dead unit but i fear that may be the solution instead of something a little cheaper or easier.
11-01-2019, 03:38 PM | #13 | |
Rep 1,255
11-02-2019, 09:27 PM | #16 |
Rep 1,255
i just took out my CIC..i saw a blue 15 fuse in the back , before replacing the CIC unit i replaced the blue fuse. it works now, but the problem is intermittent. so i will wait 2 days to see how it does before replacing the CIC
11-04-2019, 08:03 AM | #18 |
Rep 318
potential coincidence, only time will tell right now. did you unplug the quad lock and put it back on? potentially reconnecting could solve your problem, provide better contact on the connector blades. it if the CIC unit is truly failing it will come back up as a failure. just curious how much was a replacement CIC head unit?
11-04-2019, 05:54 PM | #19 | |
Rep 1,255
no, all i did was replace the fuse. i should have unplugged it though...damn. it cost 300$ for a used one off ebay that was tested off a 13 m6 |
11-11-2019, 03:18 PM | #21 |
Rep 1,255
