11-14-2021, 02:47 PM | #23 |
Rep 2,385
11-14-2021, 02:51 PM | #24 |
Rep 7,224
11-14-2021, 04:10 PM | #26 |
Rep 4,821
I put this stuff on our shower glass in Asheville before the shower was ever used:
https://www.nanovations.com/nano-glass-coating.htm Works incredibly well. Sure wish I knew about it when we remodeled our FL bathroom.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
11-14-2021, 04:12 PM | #27 |
Rep 4,821
Dawn Powerwash for outdoor cleaning, such as sliding door frames.
Also Barkeepers Helper or Bon Ami for cleaning lots of stuff where a mild abrasive is needed. I use it in annual deep clean of my grill.
11-14-2021, 06:41 PM | #28 | |
Rep 5,577
Dawn Powerwash Spray and cold water are also an excellent way to wash eyeglass lenses. |
RickFLM410968.00 |
11-15-2021, 08:48 AM | #31 |
Rep 1,965
Invite all your neighbors over for dinner.
After dinner, kill them, enslave them or imprison them all and take their land to establish dominance. Sorry, the holiday next week has me in a Thanksgiving kinda holiday mood. Seriously though, change the direction of your ceiling fans twice a year. Counter clock-wise in summer to push cold air down and the hot air up, reverse for winter months. Should save you between 7-10% on your energy bills. Drill a hole in the back/lower section of your trash can. This allows the full trash bag to be easily lifted out, rather than creating the suction effect. I also keep a sock of rice in the bottom to reduce odors. |
11-15-2021, 09:25 AM | #32 |
Rep 4,821
Put dry pasta, rice and flour in the freezer for a week to avoid weevils, also known as pasta bugs.
11-15-2021, 09:38 AM | #33 | |
Rep 1,011
Sealing interior things didn't work, exterminator and poison didn't work either. I finally called a wildlife remediation company. They don't use poison that way you don't end up with dead mice in the walls rotting away. They put some traps in the attic above the garage and made sure the entire EXTERIOR of the house was completely sealed. Then they come back and check the traps every week for 4 weeks. By week 3 no more in the traps, and we haven't had any problems since in the last 9 months. $1400 well spent. |
11-15-2021, 09:45 AM | #34 | |
Rep 1,247
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
https://www.amazon.com/Spray-Can-Noz...J%2CB06Y44MMT6
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
11-15-2021, 10:05 AM | #35 |
Rep 5,728
Drives: 2019 M2 Competition
Once the coachroaches have formed an HOA, it's time to call the exterminator.
11-15-2021, 01:53 PM | #36 |
17980
Rep 9,377
Put masking tape anywhere you are going to drill/saw, and the edges of the wood won't splinter.
11-16-2021, 10:21 AM | #37 |
Rep 2,873
You can cut a long length of wire coathanger and chuck it in your drill to put a starter hole through a wall or other material that is too thick to run a normal long bit thru - use dykes/plier cutter so the tip is sharp. Don't re-use it more than a couple of times - the heat will make the tip brittle, and you don't want it to break off in the pilot hole.
putting a little bar soap on the screw threads will make for easier install, especially in hardwoods (just pull the screw along a bar lightly). |
11-16-2021, 12:35 PM | #39 | |
Rep 1,965
Or you can just use ultra high molecular weight polyethylene film coated with a pressure sensitive acrylic adhesive. Otherwise known as UHMW tape. https://www.amazon.com/dp/B07JFTYPWK...dDbGljaz10cnVl |
11-16-2021, 12:54 PM | #40 |
Rep 19,524
I needed just one 6' fence panel to protect a side entrance so instead I did a bodge job lashing the loose edge of it to neighbours concrete post with a thick nylon string going over a strengthening piece of wood on the other side. I didn't want to order just one panel.
11-16-2021, 12:55 PM | #41 |
Rep 1,004
There is a technique for every job that will make it better, and sometimes faster. It is worth learning before starting. Old days we’d chat at the hardware store, now it is YouTube.
I used to believe in buying or renting the right tools for the job. Now I understand that the more tools I own, the more jobs I take on. So I got rid of all but the basic tools in our last relo. |
11-16-2021, 01:13 PM | #42 |
Rep 1,965
There is simple genius to this.
11-16-2021, 04:24 PM | #43 |
sportscars only
3244
Rep 3,195
For those w OCD about not making holes in walls, 3M Command Hooks/etc are a godsend (some can even hold 25lbs+!). The only holes I have are for the TV and window coverings.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
11-16-2021, 04:28 PM | #44 |
Rep 5,369
Spring-loaded punch. It will punch a pit in hard metal, wood, sheet rock, whatever. I use it all the time to set a point for my drill.
https://www.amazon.com/General-Tools...a-428924058137 Dry wall anchor screws. No more fear hanging heavy items on walls. Yeah, it creates a big hole when you remove them, but it's easy to fill. https://www.amazon.com/Drilling-Dryw...93753802&psc=1 Tools, tools, tools. Use the right tool for the job. It makes life much easier and will give you confidence.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
