      02-25-2021, 12:47 AM   #1
Alghaiti513
Drives: 2013 650i gc 2011 X5 50i
2013 bmw f06 gc transmission issue
*first post -I've had My 2013 650i gran coupe for about a year now with absolutely no trans issues whatsoever and all of a sudden failure! The first time it happened I was turning left and went dead with barley any movement when hitting gas pedal while the engine revs normally. I immediately pulled over turned car off waited a minute and started , all back to normal . About a week later same thing happened while turning left and this time restarting wouldn't help at all . Got it towed home and started to assess the situation. I started car put it in gear (which shifts into gear normally) but car will barley move unless I give it a rolling start . It shifts into drive and reverse no problem but still no movement and when I try to put it in park it give me an error message saying I have to press brake to put it in park which I am but still won't unless I put it in neutral first and then park . Any advice from anyone here will surely be appreciated
      02-25-2021, 02:32 AM   #2
hugo_nz
hugo_nz's Avatar
3184
2022 BMW IX  [0.00]
Could be a range of things but my money would be on a failing transmission control module. Were there any warnings on the iDrive?
      02-25-2021, 07:45 AM   #3
Opie55
Drives: '15 650i Convertible
I'm with Hugo. The fact that it behaved normally the one time after restart indicates that the failure is not mechanical, but electrical.
      02-25-2021, 01:00 PM   #4
Alghaiti513
Drivetrain malfunction was the only indicator on I drive
      02-25-2021, 02:25 PM   #5
Wanwansuii
Drives: '14 BMW 640i Gran Coupe Msport
If I remember correctly, I read somewhere that the TCM is covered on extended warranty. I forgot the mileage limit.
