      02-19-2021, 03:42 PM   #1
NDAzone
Drives: BMW 640i Gran Coupe
Hi all, I was thinking of getting a second set of wheels for my summer tires since I have Pirelli run-flat snow tires on the stock 20's. I figure if I keep swapping between winter and summer tires, the tires will get trashed. Am I wrong?
Anyway, the M6 wheels I am looking at getting are the style 433 OEM wheels. They are also 20" but wider with a different offset. They are 9.5 inches wide with a 31 mm offset (I'd run a square setup with the same rim size all around.).
My current wheels are 8.5 inches with a 33 mm offset in front and 9 inches with a 44 mm offset in back.
Will the M6 front wheels fit my car on all corners? I also have 12 mm spacers up front and 15 mm spacers out back. I suppose I would have to remove them for the new wheels.
Thanks for any input.
Chairman of the board.
2016 Alpina B6
      02-19-2021, 09:03 PM   #2
AccordTR
AccordTR's Avatar
Nope M6 wheels won't fit. M5 wheels do thou.
M Sports Edition
Carbon Wing
Carbon Front Splitters
Carbon Rear Diffuser
Carbon Grilles
CPG intakes
Arm catless downpipes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      02-20-2021, 07:37 AM   #3
NDAzone
Really. I'm surprised. Thank you.
2016 Alpina B6
      02-20-2021, 08:47 AM   #4
AccordTR
AccordTR's Avatar
Front will stick out past fender considerably
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      02-20-2021, 12:28 PM   #5
NDAzone
Thanks. So I guess I'll be looking for an aftermarket wheel. I have not seen any wheels with a 44mm offset.
2016 Alpina B6
      02-21-2021, 10:51 AM   #6
NDAzone
So it looks like I will go with Forgiato wheels. Pricey...
2016 Alpina B6
      02-21-2021, 08:52 PM   #7
AccordTR
AccordTR's Avatar
Looks nice.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      02-22-2021, 03:12 AM   #8
easty027
easty027's Avatar
16
Drives: BMW 640D MSPORT
id go bottom left, the rest look like they are from a 90's rap video.
CURRENT BMW: 2017 ALPINE WHITE 640D COUPE
PREVIOUS BMW'S: BMW 325 CI M Sport Coupe E46 / BMW Z4 3.0i roadster E85 / BMW 535d M Sport E60 / BMW 520d M Sport Business Edition E60 / BMW 730d M Sport. F01 / BMW 520d M Sport F10
NDAzone13.50
      02-22-2021, 12:04 PM   #9
shine775
Scott
shine775's Avatar
Drives: BMW 640i
2013 BMW 640i  [0.00]
I have seen a lot of 433 M6 wheels on 640 and 650. I'm pretty sure they fit with no problem.
Scott
      02-22-2021, 12:29 PM   #10
Mck444
Drives: 2014 BMW 650i
Running these in black on my car. No spacers though.
      02-22-2021, 04:44 PM   #11
AccordTR
AccordTR's Avatar
Nope. Rear fit no problem front do not, they protrude past the fender considerably. Remember M6 has wider front bumper and fenders. M5 wheels will fit front and rear thou no problem. My guess what your seeing is the knock offs of similar style, my buddy has them on his Camaro actually.
This is from another forum but it explains it nicely:
F12 M6
Front wheel 9.5JX20 ET:31
Rear wheel 10.5JX20 ET:19
F12 650i
Front wheel 8.5JX19 ET:33 Width and offset is same for 20"
Rear wheel 9JX19 ET:44 Width and offset is same for 20"
Using offset calculator here: http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Front wheel you will need 11mm additional space on the inside and extra 15mm on the outside of the wheel compared to your current wheel.
The rear wheels will stick out an additional 44mm vs your current wheel.
M5 wheels
Front wheel: 9JX20 ET:32
Rear wheel: 10JX20 ET:34
Front wheel you will need 5mm additional space on the inside and extra 7mm on the outside of the wheel compared to your current wheel.
So it appears as if the M6 rear wheels wont fit as it needs much much more clearance. Honestly I don't know how much extra space you have on the rear so you may want to measure it to double check.
The rear wheels will stick out an additional 23mm vs your current wheel.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
NDAzone13.50
      03-07-2021, 06:33 AM   #12
Bigjule1111
He's correct. The front would pertrude big time ...the rears would fit perfectly... Dig around , there's a old post from a member that had them put on and it looked silly ..if i remember correctly , he was considering doing modification to the front to have them fit better😳😳😳 😱👎
      03-09-2021, 01:58 AM   #13
Jeffro75
Jeffro75's Avatar
Drives: 2015 640i GC Estoril Blue
All the 640 / 650's people are seeing with 433 style wheels are running after-market which are available at the correct offset - I know, I'm one!
      03-09-2021, 06:57 AM   #14
shine775
Scott
shine775's Avatar
Drives: BMW 640i
Looks good man. Where did you find that M badge for your grill?
Scott
      03-15-2021, 11:26 AM   #15
shaddylynn
Drives: BMW 650i Covertable
Where did you find them?
Are these 20" wheels? I've only been able to find 18" replica 433 wheels. Looks really nice.
