10-04-2018, 01:41 PM | #1 |
Rep 16
Tire shaving
Does anyone know what tire shaving is?
If yes please recommend some shops who does in Ontario, Canada. I have Michelin PSS tires and front are new and rears are about 75% life. I would like to shave front tires to same thread as rear due to transfer case jerking while accelerating hard. Normal driving is fine but I could feel something is slipping when I floor the accelerator. I am confirm that is it due to different thread wear since I switched the tires to factory wheels and tires and problem goes away. I am running the right tires front and back and less than 1% of difference when NEW. 255/35/20 Michelin PSS front on 9" rim 295/30/20 Michelin PSS rear on 11" rim |
10-04-2018, 10:40 PM | #3 |
Problem Solver
111
Rep 416
I personally would be reluctant to do anything intentionally to compromise the integrity of a tire. Keep in mind that the contact patch is the only thing keeping 4,250 lbs in contact with the ground at any given time depending on road conditions, tire pressure, and speed. Please be careful having that tire shaved, long term and safety first, might want to invest in new tires and proper alignment. Just my 2 "sense".
http://paws.kettering.edu/~amazzei/tire_calculator.html
You need people like me so you can point your f*ckin' fingers and say, "That's the bad guy". "Das ist der Bösewicht". Last edited by DerBosewicht; 10-04-2018 at 10:48 PM.. |
650GC14.50 |
10-05-2018, 12:07 AM | #4 |
Rep 738
Shaving a tire does nothing to the "integrity" of the tire other than cut down the tread depth. TireRack will do it when you buy new tires from them for $20 a tire. Racers always cut new tires down so you don't get excessive tread movement. |
650GC14.50 |
10-05-2018, 01:10 AM | #5 |
Rep 2,349
What I find interesting is that most of the xdrive cars from the 5 and 6 series range have about 1% smaller diameter tyres at the rear.
By going up 10mm width at the front and 20mm width at the rear you've actually matched the front and rear diameter, but then with your different tyre tread depths you're actually closer to stock than with new 255/35 and 295/30. Have you tried turning DSC completely off and seeing if it does the same thing? |
650GC14.50 |
10-05-2018, 06:33 AM | #6 | |
Rep 16
10-05-2018, 10:37 PM | #7 |
Rep 2,349
Perhaps you could search on ebay or whatever auction site is common in Canada and try to find 245-265/35 and 285/30 tyres and play with a few different ways to do it?
I'd really be curious to see what happens with your tyre shaving but I'd be worried that you're going to remove some tyre life on some nice expensive tyres! |
10-06-2018, 08:15 AM | #8 |
Certified Car Nut
93
Rep 458
Not worth doing for the questionable benefits.
Current: 2018 Range Rover Velar First Edition D300 HSE + 2018 AMG GT-C Coupe + 2013 6 Series BMW GranCoupe (October) Retired: 2016 AMG-GTS Coupe, 2013 & 2012 Maserati GranTurismo MC Stradale,2016 3-Series Touring, 2009 5 Series GT, 2007 BMW M5, 2012 & 2006 BMW 1 Series |
10-06-2018, 04:42 PM | #9 | |
Problem Solver
111
Rep 416
but I guess when you say it like that...tire shaving does no more damage to the "integrity" of a tire than do doing a proper burnout....
You need people like me so you can point your f*ckin' fingers and say, "That's the bad guy". "Das ist der Bösewicht". |
10-06-2018, 05:30 PM | #10 |
Rep 738
I would suggest that shaving does absolutely nothing to the integrity of the tire. I would hold that there is no such thing as a "proper" burnout when you are talking about the life of a tire. The extreme heat generated in a burnout or multiple burnouts will most assuredly negatively affect the integrity of the tire.
Havy303.00 |
10-07-2018, 04:50 AM | #11 |
Rep 709
Tire shaving generates the top performance of a tire. Unfortunately only for a short period of time. As Walt said If you do some burnouts it is also like shaving but the tire received several heat inputs and looses performance as he hardens up.
10-07-2018, 03:31 PM | #12 | |
Problem Solver
111
Rep 416
