04-27-2019, 10:34 PM | #1 |
Rep 73
Drives: 2017 650i GC xDrive M Package
Coding apps
Is the consensus that Carly is the best solution? Also according to my car's data card I have an option on my vehicle - WiFi OBD2 Diagnostic Scanner
Not sure what that means. Is it built in and I do not have to buy third part hardware/ software? Any thoughts?
2017 650i GC xDrive Black Sapphire Metallic, Cognac Leather Interior, M Sport Edition/ Package, 20' Wheels, Driver Assistance Plus, Harman Kardon, Apple Carplay
04-28-2019, 03:21 AM | #2 |
Rep 119
As far as coding goes, I use carly as find it easy to use. Bimmercode is very similar too but if you are more computer literate than me you could try esys which give you more coding options.
04-28-2019, 12:20 PM | #3 |
Rep 396
Interested in learning more about esys. I used Carly for a year, but there are things I'd like to do, such as flashing OEM firmware to the car (to reset to factory settings) and coding in the anti-glare headlamps.
04-29-2019, 03:20 PM | #5 |
Rep 2
Drives: 2018 640i xDrive GT
Hi All, I new to this forum. I have a 2018 BMW 640i xDrive GT and i brought the Carly for BMW Adapter and Full App. I trying to code the VIM and the app is tell me to deactivate the speed lock in my xDrive in order for the VIM to work. How do I deactivate the speed lock and what is speed lock?
04-30-2019, 01:40 AM | #6 |
Rep 1,820
It all depends on what your definition of "best" is. I used NSCExpert on my E-series cars and now Esys and ISTA on the F12. The learning curve with Esys is much lower than that of NSCExpert, but it is still by now means a "point and click" solution. If you are just looking to tweak some settings then the likes of Carly etc. should be fine. Anything more in depth like flashing modules or complicated retrofits and your only option is Esys.
04-30-2019, 11:35 AM | #7 | |
Rep 396
04-30-2019, 03:07 PM | #8 | |
Rep 1,820
04-30-2019, 06:31 PM | #9 |
Rep 396
So, it restores defaults. Fair enough. Now, what would I use to completely re-flash the code with the most current software for the modukes, or would that be asking for trouble?
05-14-2019, 03:51 PM | #10 |
Rep 73
Dumb question:
If I get BimmerCode does that also include car diagnostics. From what I see on YouTube the app gives you many options to customize your vehicle but does it also read fault codes etc? |
05-14-2019, 09:08 PM | #11 |
Rep 1,820
You would also use ESYS for that, but it's not advisable if you do not have a high quality external PSU for the car since some of the modules can take several hours or more to flash.
