      02-13-2020, 08:50 PM   #1
RagtagXMASTER
RagtagXMASTER's Avatar
119
Drives: 2013 M6
Eventuri Intake Refinishing
So i had the opportunity to get a set of original blue carbon fiber intakes made by Eventuri. sadly they were scratched a little, so i decided to refinish them
A lot was learned through this process. The intakes are well made, they used a nice thick epoxy, but it yellows from engine bay heat. at least the blue epoxy does. these tubes were actually the same standard black carbon fiber, but covered in a blue tinted epoxy!, this really makes any possibility possible for carbon finishes!
Here are some pictures of the refinishing process! I will also put up finished pictures once i complete the MAF tubes, i am currently trying to get the yellowing out of the CF, proving to be a very difficult process. Final option will be hydro dipping the tubes.
mikerx5461.00
      02-14-2020, 06:01 AM   #2
AlpineKing
Drives: 2018 M6 GC
Wow! Excellent work refinishing those intakes! Had no idea either that the epoxy gave the intakes their coloring vs the actual CF
      02-14-2020, 06:31 AM   #3
RagtagXMASTER
119
Drives: 2013 M6
I recently found out about epoxy finishing for things like countertops. It is a similar process when finishing the job. You can mix color into the clear epoxy and change results. Now i do believe Eventuris new carbon fiber all has a clear epoxy weave. I have a set of blue carbon intake scoops as well and the weave is different and is a slightly different blue. That leads me to believe they are now using a blue carbon kevlar mat and then sealing it with clear epoxy. I wish i could find a technique to remove the yellowing caused by the engine bay heat
      02-14-2020, 09:18 AM   #4
phan
Drives: X5 35d, M5 SC'd, M6GC
awesome job!
      02-15-2020, 10:20 AM   #5
spikespiegel
Drives: BMW M6 comp
nice! I was curious,d o these actually boost power? Cause it sure is expensive!
      02-15-2020, 11:23 AM   #6
RagtagXMASTER
119
Drives: 2013 M6
To be honest i doubt they will. The stock i takes are very good. I would say the only thing really wanted or needed are scoops to direct the air to the snorkels better. These i consider are primarily for looks.
      03-17-2020, 10:57 AM   #7
RagtagXMASTER
119
Drives: 2013 M6
The Latest! intake tubes refinished and installed along with a carbon fiber engine cover and matching charge pipes too!. the charge pipes will be installed later as i also need to do maintenance on the turbo coolant lines soon, and will install them one i receive the parts required for that job!
I think these came out very well and can not wait to see the full effect in the sun light and I can not wait to hear the difference!
      03-17-2020, 12:59 PM   #8
Flo1989
Flo1989's Avatar
342
Drives: M6 Gran Coupe
Love that CF color - nice work!
      03-29-2020, 11:47 PM   #9
RagtagXMASTER
119
Drives: 2013 M6
The Finally! the upgraded charge pipes are in and some other misc maintenance has been done!.
      03-30-2020, 08:16 AM   #10
mikerx5
mikerx5's Avatar
461
Drives: 2014 F06, 2022 G06
Vicious! Look forward to seeing at the next meet up - if it can ever happen!
      04-12-2020, 07:58 PM   #11
RagtagXMASTER
119
Drives: 2013 M6
Intake sound
finally got a sound clip on a nice day
      09-01-2022, 09:31 AM   #12
MNhv
MNhv's Avatar
Drives: F85 X5M
Fantastic job! Mine have yellow'ed as well and I'm planning on refinishing. Did you clearcoat at all after the new layer of resin? Hoping to prevent re-yellowing and just do this once and be done with it.
      09-02-2022, 05:16 PM   #13
RagtagXMASTER
119
Drives: 2013 M6
I did. I had them clear coated as well so they had extra protection from yellowing. So far this is how they still look. don't mind the pollen dust on one intake
      09-02-2022, 05:35 PM   #14
MNhv
MNhv's Avatar
Drives: F85 X5M
Do you remember which resin, hardener and clear coat you used? I'm running low and looking to try something different as the one I have now doesn't really do a good job of self leveling.
      09-03-2022, 01:45 PM   #15
RagtagXMASTER
119
Drives: 2013 M6
I dont remember the resin but i used standox hardener and clear.
MNhv92.00
