      09-26-2019, 03:53 AM   #1
Xx__xs
Drives: m6
Exhaust tip question (beating a dead horse)
So im scouring the forums looking for one definitive and consistent answer however all im finding are wobbly numbers that change from post to post.
What inlet/downlet size tips do i need to buy to make sure it fits ?
i have a stock m6 exhaust non competition. oem tips. 2013 convertible
im trying to buy bigger tips in CF
      09-26-2019, 03:12 PM   #2
KrazyKorean
KrazyKorean
KrazyKorean's Avatar
Drives: 2014 M6 Gran Coupe
The inlets of the tips need to be no smaller than 69mm, people usually get 70mm since that seems to be the norm size. The outlet is completely up to you. Some want huge some want a little bigger.
I recommend doing 70mm inlet and 92mm outlet which is the norm I have seen and fills out the rear well.
mikerx5461.00
      09-26-2019, 08:08 PM   #3
Xx__xs
Drives: m6
thank you. do you know what the size is of our tiny stock oem tips?
i see there is 105 available..wondering if it will look nice
      09-28-2019, 08:03 AM   #4
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Mine measured 68MM OD horizontally. 67MM OD vertically, its not perfectly round.
I would recommend either 69MM or 70MM ID on aftermarket tips.
4th picture down you can see the small gap between muffler tip & aftermarket tip
https://www.6post.com/forums/showpos...2&postcount=60
      09-28-2019, 10:06 PM   #5
Xx__xs
Drives: m6
gotcha on the 70mm id. but on the od i want to do 105mm, but dont know if it will fit my new diffuser.
https://cdn11.bigcommerce.com/s-w4bm...791522.jpg?c=2
i ordered that diffuser^
      09-29-2019, 08:34 AM   #6
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
The problem is not the clearance from the diffuser. Its the gap between the 2 tips. Based on my measurement, I don't see how you can have 105MM side by side.
You can always measure it yourself to be sure. I have both of these & both measure the same.
https://www.ebay.com/itm/1PC-Metric-...UAAOSwoydWj0eD
https://www.ebay.com/itm/150mm-LCD-D....c100290.m3507
      09-29-2019, 07:02 PM   #7
Xx__xs
Drives: m6
i measured 249mm or 9.8 inches
105 times 2 is 210. so theres 39mm of play room for the tips to fit, should fit i think..
      09-30-2019, 06:35 PM   #8
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
If there is going to be a problem it will be where the gap between the tips are located. If the green lines are 105MM each then it will hit where the red arrow is pointing.
      09-30-2019, 06:48 PM   #9
Xx__xs
Drives: m6
i see,
this is a 4 inch tip right here, so its 101.6 mm
so mine would be only 3.4 mm bigger, which comes out to 0.13 inches bigger. i think i SHOULD be fine...
and i read this guy with an m5 has 105mm tips
https://f10.m5post.com/forums/showpo...64&postcount=5
so idk. lets hope it works i ordered it yesterday
      09-30-2019, 06:53 PM   #10
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
i see,
Its gonna be close, hopefully it works out.
      09-30-2019, 07:01 PM   #11
KrazyKorean
KrazyKorean
where did you get these tips?
      09-30-2019, 07:06 PM   #12
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Ebay but the seller is still out of stock. Bimmian.com had them for awhile until they closed down.
      09-30-2019, 07:06 PM   #13
Xx__xs
Drives: m6
thanks ill update
      10-11-2019, 06:15 PM   #14
Xx__xs
Drives: m6
did not fit
      11-08-2019, 12:41 PM   #15
KrazyKorean
KrazyKorean
Which tips did you go with? Post some pics! =D
      11-08-2019, 10:17 PM   #16
Xx__xs
Drives: m6
70 in 93 out. i think its a little too small, but this shits welded on now so no going back.
      11-09-2019, 01:39 PM   #17
Bigjule1111
I think they look great at 93mm. Y did u opt in for the welding? Aren't those bolt ons ?
      11-09-2019, 03:14 PM   #18
Xx__xs
Drives: m6
the way the clamps were set up did not allow it to get tightened far enough in due to the diameter difference of the muffler pipes.
so it was sticking out like crazy once bolted on. the entire tip was sticking out from the bumper. looked insanely stupid. so i had to cut the muffler pipes and weld it on to make it sit inside the bumper
      11-09-2019, 05:07 PM   #19
Bigjule1111
Oh k .. because I was looking at tips for my 640 with m6 mufflers but the ones I tried on fit were too long. Reason being that the tips have like a inner piping that restricts the tip from going in further ..plus the tips were like 6 in long .. I'm going to get the 3.5 in long ones and hope that will work without welding them ... How long are those ? If I go the welding route I rather get the 4 in tips and get those welded on as I believe u have to get 2 of the exhaust pipes removed and get new s pipe so the tips won't hit one another
