11-26-2022, 05:11 PM | #1 |
Rep 19
650i with night vision grill change
I'm looking to replace my front grille to be a gloss black one as well as get a black spoiler to match however I got stuck because my car has NV. I'm in canada so already it is hard to find anything for a decent price but then I noticed it was impossible to even find a grill for this car that is gloss black and works with night vision. Anyone know where i can find one?
11-26-2022, 07:08 PM | #2 | |
Rep 2,918
11-26-2022, 07:48 PM | #3 |
Rep 631
have you considered just painting it with 2K paint? scuff, adhesion primer, black, clear. I used that on chrome rings around my grill and it came out perfectly. Just make sure to do the proper prep to clean off all the wax before starting the painting
F06 M6 Grand Coupe CP
11-26-2022, 07:59 PM | #4 |
Rep 19
debating on it but never done it before and not trying to mess anything up or have it come out bad. Any recommended videos you know of that can help?
11-26-2022, 10:47 PM | #5 |
Rep 631
Try "paint society" on YouTube or search "rattle can paint......". You can remove the grill and disassemble it to make it easier to prep and finish. There are also several You-Tubers showing how to remove the grills. Do NOT use the "yank out" method. You will have to remove some bolts and fasteners along the upper edge of the bumper to get to the back side of the grills to un-clip them. There is actually a tool you can use to avoid having to loosen the bumper but I do not know where to get it. Remember that multiple light coats are better than very heavy coats (which can cause runs) Only the final clear coat needs to be a little heavy. It might be worth while to get a cheap can and try it out on a flat surface and then a three dimensional surface. You can always sand it back down and redo. I am not a body man or painter and had no problem doing it. It cam out as good as a professional job. It has been three years since it was done. It has been washed and waxed several times since then. Good luck
11-27-2022, 12:52 AM | #6 | |
Rep 107
11-27-2022, 09:04 AM | #7 |
Rep 2,918
It does not "come off" in the sense that you can pry it off or it's held on with plastic rivets or anything. I've had my grill out, and the holder is just part of the molded piece. Could a creative person cut it off and plastic weld or otherwise attach it to a standard grill? Probably, but I personally cannot imagine wanting a different color grill that badly to go to that trouble.
11-27-2022, 09:13 AM | #8 |
Rep 2,918
And to add to what I just said, even if you did attach it you would probably mess up the shiny black finish on that part of your new grill, and the NV holder would not match and would be to be painted anyway and still would not be a perfect match. I think the best solution is to be a pioneer in rejecting the current blackout craze. I'm not a fan.
11-27-2022, 12:26 PM | #10 |
Rep 7,534
Nope..the M6 logo doesn’t come off…but yep…the grilles will fit in the holes because the M6 grilles have the same dimensions as the regular kidney grilles used in the rest of the f series line.
11-28-2022, 03:13 AM | #11 |
Rep 107
The Alpina has a different slat design. Does it still fit in the same hole?
11-28-2022, 11:34 AM | #12 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
I feel your pain, I removed and disassembled mine and sent it out for paint to bodyshop along with all the other chrome trim on the car. (Fender grills, door handle trim and rear trunk emblem surround)
It is possible to remove it and separate the NV camera assembly from the grills.
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
11-28-2022, 04:47 PM | #13 | |
Rep 7,534
How are the Alpina grilles different?
11-28-2022, 09:18 PM | #14 | ||
Rep 107
Do the M6 and 650 and Alpina have interchangeable grilles? When I checked eBay (not reliable) and tried to buy M6 grilles and entered my vehicle for compatibility it said not compatible. From C&D: Oh, and the front chin spoiler is redesigned, the grille kidneys are a smidge bigger, and the hood's character lines are more pronounced. From BMW promo: A more-dynamic front spoiler and fascia enclose the subtly-revised BMW kidney grill, and shape the transition to the new ALPINA hood which features character chines |
11-29-2022, 05:58 AM | #15 |
Tinker
39
Rep 161
11-29-2022, 08:29 AM | #16 | |
Rep 2,918
11-29-2022, 03:11 PM | #17 | |
Rep 7,534
The design is different (pre LCI) 10 slat vs (LCI) 9 slat vs M6 double slat...but they all fit into the same hole. I have replaced my pre LCI 10 slat kidney grilles on my 2013 & 2015 650ix GC with LCI 9 slat kidney grilles...and the M6 dual slat grilles are all over the internet with aftermarket grills removing the M6 from the left grille. I would interpret the reference to the "smidge bigger" & "subtly-revised" to the design of the individual slats (which is true) rather than the diameter/circumference of the grilles. The 9-slat LCI grills are bigger at the top and then taper down towards the bottom...and their sides are black. This is how they "fill-out" the same circumference as the narrower 10 slat pre-LCI grilles...which have two tones of gray on the side and are slimmer than than the LCI slats. Here's aftermarket M6 dual slat grilles with the M6 removed: Here's M6 dual slat grilles with the M6 badge: Below are pics of the LCI 9 slat grilles & the pre LCI 10 slat grilles:
11-29-2022, 03:31 PM | #18 |
Rep 7,534
Here's a pic of a 2019 6 series that I ran across...it took me a minute to figure out what was going on with it...then I noticed that it had mixed matched kidney grilles. One side is the original LCI 9 slat (smidge bigger slats)...the other side is the pre LCI 10 slat (smidge thinner slats)...but they both fit into the holes (opening)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-29-2022 at 03:38 PM.. |
11-30-2022, 08:13 AM | #19 | |
Commander
221
Rep 850
11-30-2022, 08:34 AM | #20 | |
Rep 2,918
11-30-2022, 04:31 PM | #21 | |
Rep 19
11-30-2022, 06:45 PM | #22 | |
Rep 2,918
I'd personally keep the camera so you can sell the car with the options it came with since the button is there. I don't use mine either, but it would certainly affect my decision to buy a car if somebody ripped it out. But as a side note, you actually do use it all the time, you just don't know it. As I understand it, the button simply turns on the display on the screen, but the system itself is always operating and if you come across a deer on a dark road it will display a warning in the cluster. |
