08-17-2020, 09:07 PM | #1 |
The Dovahkiin
312
Rep 148
Before I break something.
First, the roof trim cap on the right side has broken off. (A picture below for reference.) Has anyone removed the trim piece and can explain the safe way to lift it without snapping it into pieces? I've reference diagrams, but can't get a proper handle on how it is actually done. I want to order the end cap and replace it myself, if possible.
Second, the trunk roundel has started to show signs of corrosion. Is it secured by the 2 nibs and double-sided tape like the front roundel? Appreciate the help. Broken trim cap. (Click image for larger pic) Roundel Corrosion (Click image for larger pic) It looks worse in person. Obligatory (cell phone) car shot (Click image for larger pic) Don't beat me up for the poor parking. It was shot in front of my parent's house just before leaving. |
08-18-2020, 03:14 AM | #2 |
Rep 11,891
#1 - if your car have gotten the brake light recall done at the dealership, then the dealer probably messed it up on install. I would pose this question to the service advisor to see if they can fix it for you for free. Maybe it is a related part that gets touched as part of the fix.
#2, don't know, but I also have this issue. Last edited by Flying Ace; 08-18-2020 at 09:35 AM.. |
MMMM6GC275.00 TinCanSailor629.50 |
08-18-2020, 06:03 AM | #3 | |
Rep 333
For reference, while doing the replacement on my car, they managed to fold the rubber seal around the brake light ... under it. It had to go back a second time to be re-seated, and the seal is bent and creased now Also, they dropped Loctite on the rear seat and burned the leather Lucky for me I spotted this within 5 mins of leaving the dealership as I needed gas. Lucky for them it landed on the center armrest and that's all they had to replace... Hope OP gets to the bottom of how that trim piece was damaged. RE the rear emblem, here's the diagram: https://www.realoem.com/bmw/enUS/sho...diagId=41_2152 Quick search of the p/n shows some detailed pics: https://www.turnermotorsport.com/p-9...uine-bmw-part/ IND Roundel / Installation https://ind-distribution.com/collect...runk-roundel-1 |
08-18-2020, 06:59 AM | #4 |
Rep 242
https://www.newtis.info/tisv2/a/en/f...oof/1VnXLBZBHo https://www.newtis.info/tisv2/a/en/f...strip/GAKmAIfM |
08-18-2020, 09:37 AM | #5 | |
Rep 11,891
08-18-2020, 12:42 PM | #6 |
The Dovahkiin
312
Rep 148
I did indeed have the recall done recently. My fault for not scrutinizing that part of the car when picking it up. I was too focused on making sure there were no scratches to the wheels or paint. I didn't notice until in the garage and wiping the back window. I also noticed the right side of the third brake light doesn't seem as secure as the left. I'll be going down to BMW later today or tomorrow and having a word.
These are the reasons I prefer to do my own work when able. Appreciate the responses. |
mikerx5461.00 |
08-25-2020, 03:37 PM | #7 | |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
11-14-2020, 10:53 PM | #8 |
The Dovahkiin
312
Rep 148
I never posted the conclusion to the broken trim piece. BMW did sort it out. It did take several weeks for it to be ordered, shipped from Germany, and then painted. The service advisor and I laughed at such a small piece of plastic taking all of this to ultimately get done. The bottom line, though, BMW made it right.
I've yet to do anything with the corroded roundel. |
11-15-2020, 08:10 AM | #9 |
Rep 582
11-16-2020, 11:26 AM | #10 | |
Rep 7,475
In regards to the rear Roundel...someone on another forum just asked this question and when I looked at the part database...there's only one Roundel part nbr listed for the f06/f12/f13...and the QTY column is listed as 2. Which means the same Roundel is used for the hood and the trunk.
So heating up the adhesive (like with a hair blower) will probably soften it so that you can carefully take a pry tool to start lifting it off (just like the front). Quote:
