      06-29-2018, 07:12 PM   #23
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
My tech said drive aggressively too. I also drive s3, mdm, sport plus suspension, sport plus throttle and sport steering (unless raining). I am second owner so maybe first babied her (he was a late 60s owner)
      06-30-2018, 03:40 PM   #24
aann
Drives: f13 M6 2016
Hi ,
today i checked my oil level and it wasn't at the maximum level , it was little bit under , and i got message says ( Engine oil level is ok ) as on the picture .
Am I on the safe side ? or i need to add more oil untill it reachs the maximum oil level ??
      06-30-2018, 05:04 PM   #25
sw1183
sw1183's Avatar
Drives: 2013 BMW M6
2011 BMW 335xi  [0.00]
Just wanted to respond that my S63 engine is consuming quite a bit of oil also. Bought with 25,800 miles, changed at 28,300 to liqu-moly 5w-30 (9.5 qts) and added Ceratec after an engine flush. I now sit at 32,300 and it seems every 1000miles I'm adding a quart of oil.
This is my weekend fun car that is tuned with HCP, downpipes, intakes with new plugs and sees multiple 60-130 pulls a week.
I had blackstone report done with nothing out of the ordinary on first oil change and will do again on July 5th. Just adding data to the thread.
2013 BMW M6
HCP e85 tune, VRSF DP, BMW CAI
      07-01-2018, 02:14 AM   #26
aann
Drives: f13 M6 2016
Im just bieng curious what is your 62-124 (100-200 kph ) time ?
I have HCP tune too.
      07-03-2018, 07:35 AM   #27
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
aann, no you do not need to add oil, can way until first warning.
sw1183 1000 miles per quart is not too bad. Try 5w-40 if you want to see possible slower consumption.
      07-27-2018, 10:49 PM   #28
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Mine is a 2014. Bought it CPO at 5400 mi. I am now at 24500 and for the FIRST time, I had to add oil. I've had dealer oil changes so far. No change in my driving habits. I ended up going with Mobil 0W 40 for the top off and will likely switch to it on my next oil change. Guys at the M5 forum seems to have good experience with it with decreased oil consumption.
      08-01-2018, 10:06 PM   #29
Bobby_Drake
390
Drives: '16 X5M
Are you using Mobil 0W-40? From their website, they are no longer "BMW Approved". But they still have the European car formula.
      08-02-2018, 06:46 AM   #30
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Well my test is now over (for now). My timing cover case was leaking oil so they replaced and as part of the work, they did a full oil change. Back to 0w-30. Maybe this will solve the loss of oil?
      08-07-2022, 09:24 PM   #31
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
During the "hot" season, you can use 5W 30 or 5W 40 to reduce the oil consumption a little bit. In very cold weather, you should stick to a 0W XX to have good lubrication at startup, which is the period of highest wear.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      08-07-2022, 09:39 PM   #32
danielgmanm6
danielgmanm6's Avatar
Drives: 2013 BMW ///M6 F13
2013 Bmw M6  [0.00]
  [0.00]
  [0.00]
Not sure why you would go to 10w40 instead of 5w 40? If you were using 0w 30 originally i would slowly increase the viscosity instead of just jumping to the thickest right away. 0w30>0w40>5w 30>5w 40> 10w 40>5w 50 (not on recommended list). The first number is important depending on climate where you live. I would never run 10w anything in these IMO. I like the cold start protection of the 0w. I'm using 0w 30 but may move to 0w 40 for the increased viscosity at high Temps. It takes longggg for mine to warm up, can only imagine what 10w 40 would take. Some ppl on here know what they're talking about but some just talk.
      08-09-2022, 12:22 PM   #33
M3talllic
M3talllic's Avatar
Drives: M3 E92 & M6 GC
I have 107,xxx miles on my M6 GCComp and have never had to add oil. I've had the car since 45k miles and I have been meticulous with it since. I change oil every 4K miles with BMW 5w40. Take climate, from where you live, into consideration when picking your oil. I live in SoCal so we don't see cold temperatures much, or if any at all😅.
Tags
oil burning
