      07-30-2018, 12:50 PM   #1
hl0m4n
hl0m4n's Avatar
Arrow ► Winter Tire Options For 20" 343M Wheels
i can not find matching front/rear winter tires fitting the oem 20" 343m wheels.
some have the rear in oem size and some front but haven't found same tire having both front and rear sizes available. i do not want to mix/match tire brands.
am i missing something or does everyone use the oem 20" winter tire set from bmw with 409m wheels?
      07-30-2018, 11:01 PM   #2
Kkgy79
Drives: 2013 m5
I put 255/285 pirelli sotoaero3
      01-27-2019, 07:00 PM   #3
AVandelay
Ranking Member
AVandelay's Avatar
Drives: 760i // X7 M60i
Did you ever figure this out for the staggered OEM setup?
      01-27-2019, 08:51 PM   #4
Kkgy79
Drives: 2013 m5
There is no exact oem size winter tires.
So i put 1 size downed 255 for front and 285 for rear.
It fits perfect and feels same as oem summer tire
I hope this help u out
      01-27-2019, 09:15 PM   #5
AVandelay
Ranking Member
AVandelay's Avatar
It does! Thank You
      01-28-2019, 02:31 PM   #6
Flying Ace
Flying Ace's Avatar
4985
just fyi, if you want a dedicated set, you can try buying OEM 19 inch wheels from the M6 coupe and maybe the M5 (M5 offsets are different). I'm going to guess you can find more options in the 19 inch sizes:
M6 Style 344: 19x9.5, 19x10.5 265/40/19 295/35/19
M5 Style 345: 19x9, 19x10 https://www.ecstuning.com/Search/SiteSearch/style_345/
      01-28-2019, 10:19 PM   #7
hl0m4n
hl0m4n's Avatar
i found porsche has same tire sizes for winter setups 265/295 20" and ended up with pirelli sottozero serie II. i didn't want to downsize size to:
1) offer maximum rim protection (low side wall already, didn't want less width to cover rim)
2) maintain same radius for driveability
i have ccb so downgrading to 19" was not an option.
      01-29-2019, 06:03 AM   #8
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
yep. +1
I use sommer/ winter same size 265/295. Winter are Pirelli and the 295 is actually 325 . Sommer I will change to Michelin. If you use the same size for sommer and winter you don't feel any differences in driving whereas changing to 19" the entire feeling is different.
      01-29-2019, 09:05 AM   #9
Kkgy79
Drives: 2013 m5
Yes sirie 2 is available. But the reason why indidnt puck it is it came out 2008. Its still ok but i pick sotozzero 3 for better technology
      01-29-2019, 10:33 AM   #10
JC04
Drives: MX
Check out the Michellin PILOT ALPIN PA4 N-SPEC at tirerack. Read the reviews and testing have done in there.
It's the best winter tires I have driven on and I have used over 5 different sets of winter tires already.
They have 255/40/20 and 295/30/20. However, driving in the winter with that thin side walls and wide rear tires aren't very ideal. I was in a similar situation and I made a decision to buy the OEM 19" wheels and put on the 265/40/19 on all four corners. I live in MN and so far it's exceeding my expectations of handling in snow and dry conditions.
