      01-23-2019, 03:02 AM   #1
eagmail
Drives: 2014 M6
CCB Rotors Life
Have a 14 m6 gran coupe with ccbs car is daily wear indicators look decent I’ll upload pics soon, I had a question though in the event I have to switch out rotors can I go back to stock I think not due to some suspension parts being different?
Wondering if ccbs will last me to 80-100k miles ?
      01-23-2019, 12:30 PM   #2
MetZF82
Drives: 2015 F06 M6
I'm sure it depends how you drive the car. 80-100k I would assume if you do little to no hard braking at all.
I have them also. The pads seem to be endless and never fading. Rotors seem to be healthy also at 30k miles.
      01-23-2019, 12:35 PM   #3
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
According to BMW they should last a life time. What ever that mean. But 80-100 yes.
      01-23-2019, 12:54 PM   #4
Whipple
Whipple's Avatar
263
Yeah, CCB Brakes should last the life of the car , I have 32k on my original pads and they still look new , but if you use them for heavy track use this is we’re they can wear prematurely,If you look up how it’s made on YouTube it will tell you all about them
      01-23-2019, 01:13 PM   #5
kong24680
Drives: Silverstone Metallic F06 M6 Gr
I know some of the Porsche/ GTR crowd but aftermarket stainless steel rotors to replace their CCBs. Might be worth looking into.
      01-23-2019, 05:03 PM   #6
eagmail
Drives: 2014 M6
Aftermarket seems to be pure garbage. Every single kit I’ve seen.
And I think I’m at 60k miles original pads about to change at 60 at 52k now
      01-24-2019, 11:59 AM   #7
gregmb
master chief
gregmb's Avatar
Drives: 2014 ///M6 vert
I have CCBs at 47k miles - at last oil change mechanic said I have over 50% left.
      01-26-2019, 07:49 PM   #8
dclin
Drives: FD3S
I'm really having a love/hate relationship with my CCBs. Has anybody inquired about just having replacement iron rotors made and switch to corresponding non CCB pads? Meaning keep the rotor 'hats' and calipers, have custom iron rotors made, and swap out the pads. I can't imagine the calipers take propriety sized/shaped pads.
I know it's an option, but I really don't want to switch to the regular brake calipers. From what I have found, the regular brake rotors are 400x36mm, and the CCB rotors are 410x38mm.
https://www.turnermotorsport.com/p-2...6-f06-m6-pair/
Racing Brake does make a 410x38 iron disc, but no idea if the bolt holes/pattern matches up. Not sure if there is a standard in the 2 piece brake rotor industry, like the 40 hole US standard in 3 piece wheels https://www.racingbrake.com/420x38mm...604-02-381.htm (edit* hmmm, url says '420', title says '410'. Regardless, I know there are companies that make custom rotors)
      01-26-2019, 08:16 PM   #9
eagmail
Drives: 2014 M6
Just checked mine wear indicators look great little worn have 52k miles
      01-28-2019, 02:20 PM   #10
Flying Ace
Flying Ace's Avatar
4985
just note, the wear indicator is an approximation. CCB rotor materials "burn off" rather than wear down like steel brakes. (they also wear down, but not as much)
The true way to measure the rotor wear is with a carbotech tool or to weigh each rotor and compare it to the start of life number stamped on each rotor. (each rotor has different weights at start of life due to the way the rotors are made).
More on it here: https://f80.bimmerpost.com/forums/sh....php?t=1239580
      03-02-2019, 03:36 AM   #11
dclin
Drives: FD3S
So, they actually do make a CCB->Iron rotor conversion kit =)
https://www.racingbrake.com/RB-2pc-r...-Ir-p/2472.htm
No link or pricing to the rear kit, but they do list a part number for it. Probably similar in cost to the front, so $3000 for the front/rear set.
