      09-11-2019, 03:48 PM   #1
Whipple
Whipple's Avatar
263
Key switch location in trunk
Hey Guys,I have the wireless meistershaft exhaust valves, the controller just needs a 12v pos and neg connection,I found out even when not in use it puts a small draw on the battery leading to a warning on my dash after about 5 days leading me to believe it was a bad battery.
I have been using a piggy back fuse holder in the rear fuse box for my power source but all these fuses always have constant power from what I tried.
Can someone please tell me where I can get a switched power source in the truck, what wire or maybe I missed something in rear fuse box any info would be appreciated.Thanks
      09-11-2019, 04:16 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
You need to look for the switched circuit (which stays on for about 15 minutes after turning off the car). There are several in the fuse box on the right hand side in the trunk. Try fuse 128 to 136. I seem to remember that that is a switched fuse.
See https://www.newtis.info/tisv2/a/en/f...ear/1VnXFmUESj for diagram
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      09-11-2019, 07:20 PM   #3
Whipple
Whipple's Avatar
263
You are the man!I confirmed with a tester actually fuse 128-136 is a actual key switch on and when you turn the car off it shuts off perfect ,I used 128 because its a 10 amp fuse the other ones are 5 amps ,and I fused the valves at 2 amps I had the larger fuse holder had to change it to the smaller fuse holder for those fuses, Thank you
      02-01-2023, 05:08 PM   #4
SilverM6Comp
Drives: 2014 BMW M6 Competition
Could you please advise me how you ran the power cabling from the muffler into the trunk?
