      11-04-2021, 06:15 AM   #1
Basheerm62013
Drives: M6 2013
Need help with my m6
Hello all i have problem with my m6 2013 She had an accident and fixed it the drivetrain when I start the car for the first time it come on and when I turn it off and start it again it disappears I changed the sensors in the 2 intercooler and I didn’t know what to do. Could it be the one in the minifold? . Can anyone help me? There is no bm workshop near my town
Code is (air mass system 2 plausibility calulated air mass in the air intake system not plausible. 107002
      11-04-2021, 07:10 PM   #2
byebyev8
Drives: e92 335i f12 m6
Codes for the MAF sensor in the intake. Maybe not plugged in or bad
      11-07-2021, 01:07 AM   #3
Whipple
Whipple's Avatar
263
Hi ,you said it was in an accident, so it can possibly be a cracked intake manifold ,You should do a smoke test to see were the leak is coming from ,if there is no leak then it can be a sensor ,the bad news is the engine has to be dropped in order to replace the intake manifolds
      11-07-2021, 04:31 AM   #4
Basheerm62013
Drives: M6 2013
Hi yes i replace the manifold but im think about manifold sensor can i changed with out dropped the engine
      12-10-2021, 10:55 AM   #5
warpeacelove
Drives: 550i
The engine does not have to get dropped to take out the sensors on the manifold. It has to be done from the top down
