      11-30-2021, 04:19 PM   #1
TSV
Drives: 640D Gran Coupe
Can't locate the other USB
I have a 2016 640d Gran Coupe in the UK. I need to update the maps and the usb under the armrest isn't the one I need to use. I can't find any other one. There is none where the cupholders are and none in, around, or underneath the glovebox.
Does it have one? I'm sure others have managed to update their maps, so there has to be a way.
Thanks.
      11-30-2021, 04:33 PM   #2
shine775
Scott
shine775's Avatar
Drives: BMW 640i
2013 BMW 640i  [0.00]
Originally Posted by TSV View Post
I have a 2016 640d Gran Coupe. I need to update the maps and the usb under the armrest isn't the one I need to use. I can't find any other one. There is none where the cupholders are and none in, around, or underneath the glovebox.
Thanks.
The other usb is located inside the glovebox. On the top right side.
Scott
      11-30-2021, 05:00 PM   #3
TSV
It's definitely not. Maybe because it's right hand drive.
Cheers anyway.
      11-30-2021, 07:35 PM   #4
Walt White Coupe
Walt White Coupe's Avatar
221
Drives: 2013 650ix Coupe, 23 C8 Vette
Then look on the other side/top of the glove box. The USB inserts vertically into the top of the glove box.
      12-01-2021, 05:17 PM   #5
Bluefoz
Bluefoz's Avatar
29
Drives: 640d GC Ltd Ed., iX3 Pro
It’s the one next to the cup holders at the front of the centre console.
      12-01-2021, 11:58 PM   #6
Hopefully someone with a RHD model will chime in. Those of us with LHD models & early builds (pre facelift) w/NBT ID4 have the USB in the roof of the glovebox.
If you have a RHD model, the steering wheel is located on the side of the car where the DATA/USB is located…so I’ve never heard (or don’t remember) any RHD owners mention where the USB port is located.
Our owners manual (LHD) tells us where it is located…is this info missing in the RHD owners manual?
EDIT: did a search for previous threads on this topic…below are some quotes from other forum members from Europe (RHD & diesel) owners
Originally Posted by Sonny Crockett View Post
Ok, I have checked my car and I have some updates. In the owner´s manual it is stated that cars equipped with Professional Navi and/or TV the software update should be made through the USB port in the armrest. Cars without Professional Navi and no TV should do the update through the glovebox. So there we might have an answer to that. Again, my car is a diesel built in late August 2013.
In the owner´s manual it is also stated that it can be done through BMW TeleServices, but that option did not pop up when I tried according to the instructions. Maybe the car has to be in motion?
I will take my car for service tomorrow before it is time for its winter sleep - will ask the dealer then. I also checked which version I have and was MN-003.011.002 and TN followed by the same number.
Originally Posted by FBMWWINS View Post
I just checked my car and there is NO USB port inside or around the glove box. Mine is equipped with SA609 (Navi pro). Thus it makes sense according to what is stated above in post #18.
      12-02-2021, 07:58 AM   #7
DaveS86
Drives: BMW 640I
Mines RHD and the USB is in the top of the glove box on the passenger side just below the passenger airbag symbol on the dash
      12-02-2021, 09:41 PM   #8
maron
maron's Avatar
74
Drives: E60&F06
2016 has USB on the armrest
Vehicles equipped with early CIC and COMBOX have glove box (CIC) and armrest (COMBOX) USB.
      12-03-2021, 10:43 AM   #9
Bluefoz
Bluefoz's Avatar
29
...... as your car is a 2016 I'm assuming it's an LCI therefore it's definitely the one by the cup holders under the flap at the front of the centre console - I've update my maps using that port a number of times
      12-04-2021, 09:47 PM   #10
qqcoding
Drives: 2016 640i Conv 2007 328i Conv
USB
I am having the same issue. Manual says it’s there but it must be invisible!
      12-04-2021, 09:50 PM   #11
qqcoding
USB Hidden
Thanks for that info.
      12-04-2021, 09:51 PM   #12
AccordTR
AccordTR's Avatar
Drives: 2015 650i XDrive Gran Coupe M
Thanks.
Maps are updated via the cup holder one. I've done it 20+ times over the years.
M Sports Edition
Carbon Wing
Carbon Front Splitters
Carbon Rear Diffuser
Carbon Grilles
Powder Coated 373m Triple Bronze
CPG intakes
Arm catless downpipes
Arm charge pipes
Custom Snow Performance methanol injection
Custom exhaust, straight pipes to quad tips
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      12-22-2021, 12:59 PM   #13
KingScorpio
KingScorpio's Avatar
Drives: BMW 640i
2015 BMW 640i  [0.00]
Is there a way to get free map upgrades?
      12-22-2021, 03:45 PM   #14
CardinalFlyer
Drives: 2014 BMW 650i Convertible
Not free, but $75 for lifetime updates is pretty good. I used this source when I updated my maps about a year ago. No glitches!
https://bimmernavupdates.com/shop/bmw-6-series/
      01-12-2022, 09:39 AM   #15
JeremyPL
Poland
Drives: 2016 650ix GC
You can always download maps from the Internet and ask for FSC on the forum..
      01-12-2022, 10:14 AM   #16
IREALITY
Drives: G30 and x6
Thanks.
Thanks.
Check the glovebox bro it should be there
      02-25-2023, 02:28 PM   #17
cello11
CELLO11
cello11's Avatar
Drives: BMW X5 F15 and 640 Cabrio
I had several BMW in the past. According my experience the CIC systems (up to 2013) have the USB for map and system update in the glove box opposite to the driver seat.
The newer NBT systems (after 2014) do NOT have any USB slot on the glove box, but there the update is done via the USB in the central compartment, the same USB used for playing MP3 via memory stick.
      02-26-2023, 03:26 PM   #18
Plastic Sith
12
Drives: BMW 640d GC
Late 2014 build GC owner here in the UK and map updates done using USB port in the centre armrest cubby hole.
