      06-18-2019, 01:46 PM   #1
KINOPTIK
Drives: 2013 M6 2D
upgrade the 200ah agm battery for M6??
hello all
can I try to upgrade the 200ah agm battery with for M6?
Please tell me your thoughts.
      06-18-2019, 04:05 PM   #2
Flying Ace
Flying Ace's Avatar
4985
Theoretically yes. You should try to use the largest capacity AGM that will physically fit into the battery compartment.
That said, I believe BMW only makes the 95 and 105 ah AGMs. And if you were to take it to BMW, they would recommend you replace it with a battery of the same ah as before.
Remember, you'll still have to code the battery after install
      06-19-2019, 11:20 AM   #3
KINOPTIK
Drives: 2013 M6 2D
yes,I know, I still remember that this forum has an enthusiastic partner who can help us remotely register the battery for free. I am just curious if replacement the 200ah battery is better for M6.
      06-19-2019, 02:20 PM   #4
BMWRog
Drives: 2014 M6 Convertible
Originally Posted by KINOPTIK View Post
... I am just curious if replacement the 200ah battery is better for M6.
Better? No. If you lived in Ontario Canada, then the added AH capacity possibly might help if difficulty starting in extremely cold weather was experienced. Increasing the AH won't make the car perform or run any better. I'd stick with the original capacity.
      06-19-2019, 03:22 PM   #5
KINOPTIK
Drives: 2013 M6 2D
I have encountered other problems caused by poor batteries. If there is a better choice, why not?
      06-19-2019, 07:44 PM   #6
BMWDriverX
Drives: G12 750i X-Drive
Go OEM only. BMW's are notorious for electrical issues when the battery is drained or if an aftermarket battery is used.
      06-20-2019, 10:16 AM   #7
BMWRog
I have encountered other problems caused by poor batteries...
A good OEM battery will always be better than a poor after market one. Frankly, I cannot see you'll gain anything at all by going for a bigger capacity. Unless you're trying to run some mindblowingly power hungry accessories when the engine's switched off!
      06-24-2019, 05:52 PM   #8
Flying Ace
Flying Ace's Avatar
4985
like the idrive?
