11-03-2018, 10:18 PM | #1 |
Rep 23
SPORT mode issues
Hi all! I just got my coilovers installed yesterday and am now having issues with staying on SPORT mode. It allows me to switch from Comfort to Sport during a complete stop, however, when I accelerate, it will switch it back to Comfort Mode.
When I start my car the warning says "CHASSIS: Drive Moderately". The coilovers did not have the plugs that the stock suspension came with. Could that the issue? If so, how do I fix it? Can it be fixed by CODING it? Thanks so much for everyone's expertise! |
11-04-2018, 05:42 AM | #2 |
Rep 2,534
Drives: 16 G12 + 15 F06 + 17 F15
This is why I never lowered my M6.
11-04-2018, 07:30 PM | #4 |
Rep 7,480
WOW...don't know where to start. Not knowing how much you already know and understand...but the electrical harness to your 4 shocks is connected to other modules that send data to the VDM & ICM modules as well as other sensors (steering angle, height, acceleration, etc sensors) which are also affected by the DDC (dynamic driving control) switch on the center console.
Your car is optioned with multiple interconnected suspension systems....electronic damping control (EDC), integrated chassis mangagement (ICM), and vertical dynamic management (VDM). If you disconnect the EDC shocks, then data that the ICM module is expecting to receive is disabled/cancelled and is causing these integrated systems to go into a default mode. Again, this is a lot of technical and integrated systems...the best I can recommend is to go to the www.newtis.info website and enter your VIN...then do a search for EDC, VDM, and ICM (type the actual words for the acronyms which were given above in the previous paragraph in the search box)...or look for the info under suspension/chassis links on the TIS website. It goes into details as to how all of these modules and systems are connected by the sensors, shocks, control modules, and switch on the console. Good luck. EDiT: just for a small example...you can see how the switch on the console (#14 in illustration below) is connected to a lot of other systems (this was taken from the integrated chassis management (FUB) on the TIS website): 1 Vertical dynamics management (VDM)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-04-2018 at 10:49 PM.. |
monkeyf137.00 |
11-04-2018, 10:55 PM | #6 | |
Rep 23
11-05-2018, 01:23 AM | #7 |
Rep 477
cant help but nice Ferrada wheels...
11-23-2018, 02:44 PM | #8 | |
Rep 23
JakeBMW11.50 |
11-26-2018, 10:11 AM | #9 |
Rep 7,480
Great news! Thanks for following up and letting us know you got a satisfied conclusion.
monkeyf137.00 |
11-27-2018, 12:36 AM | #11 |
Rep 477
i know not M6 but nice wheels
