      11-29-2020, 09:53 AM   #1
GiftyM6
Drives: BMW M6 GRAN COUPE
2015 F06 M6 GC - need help with spacers !
Hi guys
Anyone running 12 mm spacers with 433 wheels on 2015 M6 GC and any issues ??
TIA
      11-29-2020, 03:19 PM   #2
Rsnk60 M6
Drives: 2016 BMW M6 GC
Originally Posted by GiftyM6 View Post
Hi guys
TIA
Hi guys
TIA
As long as there hubcentric your good. And get a good high speed balance and torqued correctly.
M6 Daddy
      11-29-2020, 06:04 PM   #3
Bmwtechgeek
Drives: Bmw m5
No problems here. The car looks so much better with them.
      11-29-2020, 06:07 PM   #4
GiftyM6
Wat brand did u get ? Can you share a picture?
Thanks
      11-29-2020, 06:08 PM   #5
GiftyM6
Hi guys
TIA
Hi guys
TIA
Thanks
      11-29-2020, 06:09 PM   #6
Bmwtechgeek
Drives: Bmw m5
Thanks
I think they were H & R
      11-29-2020, 06:12 PM   #7
GiftyM6
Thanks
Beautiful car man ! I m also from Ontario
      11-29-2020, 07:47 PM   #8
Whipple
Whipple's Avatar
263
If you dont mind spending a little extra for spacers definitely go with Future classic by IND.you will have zero problems
https://ind-distribution.com/collect...r-kit-14mm-lug
      11-29-2020, 07:53 PM   #9
GiftyM6
Thanks a lot ! Do you suggest 10 or 12 mm
      11-29-2020, 08:03 PM   #10
Whipple
Whipple's Avatar
263
I went with 10mm in all 4 corners,im running stock 265 front tires and 305 in the rear the fitment is pretty damn good no rubbing,I might even try a 315 r888 in the rear with the 10mm spacers might just make it
A lot of guys run 10 front 12 rear but at that point you can only run stock width tire is a 295,If you want to run a 305 it might rub
      11-29-2020, 08:07 PM   #11
GiftyM6
A lot of guts run 10 front 12 rear but at that point you can only run stock width tire is a 295,If you want to run a 305 it might rub
Looks perfect ! My plan is to put on 305 PS4's in the rear
I heard 10 mm in the front vibrates as it doesn't clear the hub specially models prior to 2016
      11-30-2020, 03:51 AM   #12
Msparta
Drives: X6M
Not sure if spacers have any negative performance or hardware impact to the bolts at stop and go with high accelerations however I imagine because spacers just sit between hardware these have minuet but real play and tolerance that can damage the wheel bolts...
The look and stance is excellent nonetheless... I would also say the grime from the road will have more area to clean then having the wheels in their stock placement under the fender 100%... paint damage overtime on the lower door sides may or may not be a thing but just worth considering.
Great pics
      11-30-2020, 04:33 PM   #13
Whipple
Whipple's Avatar
263
Great pics
IND uses these spacers on there Race car so they did there R&D there well tested , The spacers come with all new wheel bolts to compensate the 10mm space etc, they give you anti seize and new longer hub bolts to fasten the spacers in place , I have done over 160+mph serval times with zero vibrations
I have Carbon side skirts that protect my rockers from rock chips
      11-30-2020, 11:23 PM   #14
GiftyM6
Ordered Macht Schnell 10 mm spacers for all 4 wheels. Thanks guys
Will upload pics and update if I notice any vibration !
      12-01-2020, 07:21 AM   #15
mikerx5
mikerx5's Avatar
466
Drives: 2014 F06, 2022 G06
I went with macht 12 on rear - superior quality IMO, nice choice!
      12-01-2020, 07:41 AM   #16
Petepacman
Drives: BMW M6 Gran Coupe
Nice! I have those with 12mm front and 15mm rear
      12-02-2020, 05:36 PM   #17
Bmwtechgeek
Drives: Bmw m5
Thanks
Oakville here. You?
      12-03-2020, 02:19 AM   #18
GiftyM6
Thanks
Oakville here. You?
Sauga ! Lol
      12-09-2020, 02:18 PM   #19
FinalRenegade
FinalRenegade's Avatar
Sauga ! Lol
Aye, I'm in Sauga
If you ever see a Blue M6 GC, its me!
      12-09-2020, 10:58 PM   #20
GiftyM6
Sauga ! Lol
Aye, I'm in Sauga
Haha sick
We usually chill at Terry's
      12-10-2020, 07:37 PM   #21
GiftyM6
Added 10 mm
Good fitment
No vibration at all
Thanks everyone
