      06-13-2019, 12:59 PM   #1
castlesteve
Comfort Access Door Handle Removal
Doesnt seem that there is anyone who has posted the details on an F - 6 series comfort access door handle removal.
Mine is bonkers...so I need to disable it until I can order a new one.
Anyone know if it's 4mm, 15T or 25T? Seems to be a varied instruction set and I cannot see the bolt inside the access hole at all
2017 X5M (LBBlue/Aragon)
      06-25-2019, 12:01 AM   #2
castlesteve
I'll follow up and answer my own question.
Pulling back the rubber cover on the inside of the door exposes an oblong, hotdog shaped access hole. From that hole, you can use a T25 to loosen the screw (it remains in place) for the lock/light portion. This is not needed for just removing the handle though.
The handle is accessed with a T15 driver. Back it out a few rotations and the handle can be lifted out. The hinge side exposes the power connector for the light (2 pin connector) and the 4 pin connector for the comfort access. I just removed the 4 pin connector and put the handle back in place.
Now, the car still detects the key from the drivers door and the trunk, but not passenger side. So all the functionality is still there except passenger side. Also my battery drain warning is now gone as is the faulty detection of the key when inside the car.
      06-25-2019, 09:26 AM   #3
      12-15-2023, 09:27 AM   #4
Big G 1979
Big G 1979's Avatar
Drives: BMW 640d
An old thread I know but hopefully you are still in this group and can help me, that T25 screw you access thru the hotdog hole would it sort out my wobbly handle? my handle moves up and down a good bit
