06-14-2019, 08:32 AM | #1 |
Mad Fiddler
792
Rep 994
Sticky iDrive Knob?
Upon occasion, my ceramic iDrive knob becomes sticky - tough to turn - as it were. After a few ‘spins’ back and forth it loosens up again. Anyone else experienced this? I’m dropping the car off on the 25th for some warranty stuff, is this something I should mention to them?
06-14-2019, 08:48 AM | #2 |
Rep 282
If you spill just a tiny bit of a sugary drink like coffee or coke it does a number on it. My buttons get stick from time to time. If it is electrical which is more what it sounds like you definitely want them to look at it. Swapping them out is pretty easy, but the part is expensive. If you have the original warranty it should be a no brainer. If you are under the extended warranty they may weasel out of it because it's not covered.
06-14-2019, 09:29 AM | #3 |
Rep 2,908
Although a sticky drink may also do it, that is probably not the issue. I had 2 replaced under warranty -one lasted about 4 months - for that very reason. They start to come apart inside. It would spin fine for 10 turns, then get stiff, then free up again.
06-14-2019, 09:57 AM | #4 | |
Mad Fiddler
792
Rep 994
06-14-2019, 09:59 AM | #5 |
Mad Fiddler
792
Rep 994
Thanks for this. There have been no spills on my watch. I’ll bring it up when I bring the car in. Also, if you remember, the last time I brought it in, the dealership damaged my rear bumper. Would I be too much of an a-hole to walk around the car with the SA and video tape it at the drop off?
06-14-2019, 02:02 PM | #6 | |
Rep 282
Just be nice, and not a jerk. Same as always, and you SHOULD get the same in return. Good luck with that. |
Frupal791.50 |
06-14-2019, 05:09 PM | #7 |
Rep 2,908
I probably would not even get the SA involved. Nobody will notice you holding your phone. You just need 2 still shots. One from a front corner and one from the opposite rear corner. That covers the whole car. The background will make it clear where it is, and the photos will be time-stamped to make it clear when it is.
Frupal791.50 |
06-14-2019, 09:01 PM | #8 |
Rep 1,698
I had this problem on my 550xi. Replaced under warranty. It had nothing to do with a spilled drink (although, I'm sure that could cause similar issues), but there are well documented issues with the controller doing this - not uncommon.
Have them look at it for sure.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching Previous: '14 550xi, '07 335i, '01 325i |
Frupal791.50 |
06-15-2019, 10:03 AM | #9 | |
Mad Fiddler
792
Rep 994
06-15-2019, 06:16 PM | #11 |
Mad Fiddler
792
Rep 994
Well mine is ceramic so I guess I’ll let them know. Thanks!
06-17-2019, 12:23 PM | #13 |
Rep 2,908
06-29-2019, 07:22 AM | #15 | |
Mad Fiddler
792
Rep 994
01-21-2023, 04:34 PM | #16 |
Rep 282
I just started haveing a problem with my idrive controller know. No spills. The knob spins freely but when I push down on the knob it takes 5 or 6 pushes. Should I "spill" some WD40 under it or attempt to take apart?
01-21-2023, 07:04 PM | #17 |
Rep 2,908
No way I’d spray WD40 on it with it installed. That stuff stinks and it won’t get where it needs to go. I don’t think I’ve ever seen a thread about taking an iDrive controller apart. They are certainly not meant to be taken apart.
01-21-2023, 07:20 PM | #18 |
Rep 639
Drives: 2016 Alpina B6, 2015 535i
They aren’t meant to be, but I’ve done it to remove the black plastic ring that sometimes breaks inside and makes it feel “sticky”. I’ll try to find a link to what I mean. Just have to be careful not to break the ceramic. Ask me know I know…
Here’s a photo of the controller after I removed that broken black plastic piece from inside. |
01-22-2023, 11:20 AM | #19 |
Rep 1,356
The plastic ring is a dust sheld. It breaks all the time. You can remove it and your iDrive controller will work fine again.
When it is stiff, look at the edge between the knob and touchpad. You will notice a black piece of plastic raised up a little. Use a plastic pry tool and pry it a little to give it a little more space then use a needle or some pick tool to remove it. Once you can pull the edge off a little, you can yank the whole ring out. No disassembly of the knob is required to remove it. |
Opie551194.50 |
01-22-2023, 12:12 PM | #20 |
Rep 67
Wow...
If that tip works... by far the best bit of information I've ever seen on this forum.
Ceramic controller has been a real frustration... |
01-23-2023, 08:36 AM | #21 |
Rep 2,908
Agree that's a useful tip. My third new one has been good since 2019, but if it starts sticking again at least I know what to do.
01-23-2023, 10:14 AM | #22 |
Rep 67
This issue afflicted my ceramic iDrive controller. It's an easy fix, I used a soft plastic ruler to pry up the top of the 'spinny thing' and then fetched out that pesky plastic ring with some tweezers. Took all of 10 mins, if that. No more sticky iDrive! :-)
