      12-12-2016, 02:22 PM   #1
The0pportunist
The0pportunist's Avatar
237
Drives: F13
Tyre Pressure - Carly
Is it possible to code in live tyre pressure numbers using bmw carly app?
At the moment car only tells me when tyre pressure is low on one tyre. No figures at all
I have a 2012 640d, 20in wheels - i'm hoping she's not too old to do this!
Thanks!
      12-12-2016, 04:04 PM   #2
chris.t
chris.t's Avatar
27
Drives: 2014 BMW 640d msport
does this not depend on the type of tyre valve fitted the later metal versions have sensors that relay the pressures to the idrive screen, dont know if these can be retro fitted to earlier cars with a software update to support them they are not cheap though i personally wouldn't bother.
Present 2014 BMW 640d msport
Previous 2012 BMW X5 30d msport
      12-12-2016, 04:13 PM   #3
sewright
Drives: 2013 650i
I can't speak to the 2012 or Carly but I had my car recoded (it was previously coded)a few days ago. The recode restored tire pressure and temperature on my 2013.
2013 650i - Imola Red
      12-13-2016, 08:09 PM   #4
Jon D
Jon D's Avatar
Scotland
120
Drives: 2016 F12 640i
Can't answer your question but I understand your frustration with the system. Don't see the point in having a supposedly accurate indication unless you can read it cold and static - just a few hundred metres will increase the temperature resulting in a pressure rise.
It's obviously a software hangover from the previous ABS sensor based system but you'd have hoped a company like BMW would have applied a bit more thought....
      12-15-2016, 12:36 PM   #5
The0pportunist
237
Drives: F13
Ahh that sucks - thanks for your input though chaps.
Out of interest when did tyre pressure display become standard on the 6?
      12-16-2016, 02:52 AM   #6
Jon D
Jon D's Avatar
Scotland
120
I think it was 2013/14.
      12-16-2016, 01:01 PM   #7
WWnyc
Drives: 2014. 640 ix Vert
My '14 didn't have it but was coded in by Octopump.
      01-21-2018, 10:24 AM   #8
rodernr
Drives: 2015 650 GC
Yes, there is an option for coding tire pressure w temp via Carly in the NBT module. I have done it successfully.
      01-21-2018, 05:57 PM   #9
darms
darms's Avatar
48
Drives: 2018 330i Msport Shadow Ed
Hey bud, when I had my car coded by DD Coding, Adam advised it wasn't possible on my 2012 motor either
F30 LCI M Sport Shadow Edition Mineral Grey
      01-22-2018, 07:23 AM   #10
MBMW
Drives: 2014 650i GC
There two types of sensors depending on region 1. rotation sensor which is a more passive way of monitoring tire pressure by measuring rotation speed then alerts the driver if the it senses speed difference. in this type you cannot get pressure reading since there is no sensor in the wheel/ tire assembly.
2. TPMS which has a sensor in the assembly and it can read the pressure and temperature. Other factors will be head unit and coding. Take a look at your wheels and see if you have metal valve, if yes then it is possible. Then go to your Nav map version and see if you can see NBT if yes then you can get the reading by coding your vehicle.
Good luck
      01-22-2018, 12:21 PM   #11
elvisisdog
Drives: F06 MSport 2013/09
You should be able to retrofit the TPMS module and then get 4 valves for each wheel. I share your frustration as I was going to code this on my 63 plate but it doesn't have the TPMS module or sensors. Not massively expensive parts wise from memory about 150 for sensors and 200 for module. But 350 just to see tyre pressure seemed a touch over the top.
      01-24-2018, 10:59 AM   #12
Malik550
Drives: F06 Gran Coupe
I have also coded this myself with a different app and it works fine.
