      01-12-2022, 06:45 PM   #1
richlandforged
richlandforged's Avatar
432
Drives: F13 M6, E70 X5d, e46 330ci zhp
Sneak Peak - RF-GT4 "Project Nürburg" + Meisterschaft (Unreleased Version)
We opened our Christmas presents a little late... stay tuned
      01-12-2022, 10:39 PM   #2
Flo1989
Flo1989's Avatar
342
Drives: M6 Gran Coupe
Such an awesome system. And with yours having no mufflers…uh-oh!
      01-12-2022, 11:43 PM   #3
brad850csi
Drives: 16 F13 M6 Comp
Those are the 21" option for the F13 chassis? I really like your designs etc but could you do a 20" option?
I'm running Ferrada FR8 in 20x10 25mm and 20x11.5 18mm and would be keen on the GT4 design but only in 20"
      01-13-2022, 07:56 AM   #4
richlandforged
432
We've received several inquires on this design for a 20" option, of which we are willing to provide given interest. Due to blank allowances, foreseeable options are of the following nature:
Front:
20x10 ET28
Rear:
20x11 et+22
20x11.5 et+27
20x12 et+33
On the rears, although a bit more aggressive "poke" than OEM (about 5mm), leaves a bit of room on the table for a spacer if super aggressive fitment desired.
Contact us at info@richlandforged if interested in 20" setup!
      01-13-2022, 11:49 AM   #5
atillathetom
Drives: Bike
Hello. Is your 21x12 M6 wheel available in a et 20 or 21 to allow flush fitment on lowered cars without a spacer?
      01-13-2022, 12:21 PM   #6
richlandforged
432
The lowest ET we can produce on the 21x12 is ET32 which is 6mm more "poke/stance" than OE 343M. Inner clearance is good on that fitment on Stock suspension with 325 rear tire.
For super aggressive fitment a 10mm spacer is applicable on rear, especially for the HAS kits which have wider lower collar/spring perch than the OEM shock/strut.
In actuality we dont actually think the H&R HAS kit that is popular on this platform can feasibly be fitted with an 12" rear wheel as realistically one needs at least an effective ET+18 or ET+17, which is just too far for comfort in our opinion.
The H&R VTF kit however is made with a collar that is about 10mm less in diameter than the H&R kit, and can very successfully be run with a 325 tire/12"width.
Hope that helps!!
      01-13-2022, 12:23 PM   #7
atillathetom
Drives: Bike
How about an 11.5" option for 325? What about the collar on the Dinan Kit?
https://documents.dinancars.com/d190-1011.pdf
      01-13-2022, 12:39 PM   #8
richlandforged
432
Certainly,
An 11.5" offering would offer similar "poke" as our 12" in terms of offset, would likely free up enough inner clearance for likely all the HAS kits without spacer, but would mount a tad fat coupled with 325. To date, cant directly comment on DINAN HAS kit to date, however visually suspect it a worse candidate than the H&R VTF as the VTF kit tappers the spring coil down a bit towards perch, which doesnt appear evident on the DINAN.
Certainly like threading the needle to arrive at the perfect combo, but we're very happy to have found solution!!
      01-13-2022, 01:19 PM   #9
atillathetom
Drives: Bike
Honestly, they are gorgeous wheels but needing a spacer to sit flush isn't high on a lot of peoples wish list. I understand you are advertising an OEM+ fitment but why not go more aggressive? Your front is 9MM more aggressive than stock which would really look nice. What would be involved to produce a 12" wheel that could attain et20 or et21? To take it one step further for people wanting a 305 rear, how about an 11" wheel that was flush? Most people who run spacers on a stock rear are running 12 or 15mm. An 11" rear should be et13ish to be flush. Is there a blank that would work for this? I would have a hard time saying no.
      01-13-2022, 01:41 PM   #10
richlandforged
432
Appreciate the sentiments and interest! Each forged blank is comprised of course of material of which can be milled, and with that, a corresponding footprint for which design can be accommodated to. The applicable offsets on the F06/F12/F13 do stretch the feasible OEM+ fitments a bit deeper than that say of the F80/E90 platforms, which adds really great potential for dramatic design. To that extent, for the M6 specific version designs we have maxed out the offset of our applicable blank in order to, at minimum, improve upon the "poke" of OEM on the M6 specific fitments. Depending on desires and specific goals, identify there is still a bit of room left for reasonable spacer application.
      01-15-2022, 04:19 PM   #11
flashgordon64
FLASHGORDON64
Drives: 2015 F06 M6 GC
Man love the wheels and would definitely pull the trigger on these. But as stated above the whole reason for running aftermarket wheels is to move off of spacers to get that flush fit. I'm running OEM 433's - 275 front and 305 rear on KW HAS w/spacers. I'll definitely keep checking. Hopefully you guys will consider...
      01-16-2022, 08:15 PM   #12
brad850csi
Front:
20x10 ET28
Rear:
20x11 et+22
20x11.5 et+27
20x12 et+33
Thanks - unfortunately spacers that just slip-on are illegal in NZ and bolt-ons are ok but normally they are about 15mm thick which would probably just work with the 20x12 option.
I'll have a think about it but based on what a few others have said a lower offset would be great for us
      01-17-2022, 03:19 AM   #13
yifuuX
Drives: BMW M6 F13
Will you be offering negative ET on 20s?
My car has a widebody so it needs negative ET.
Thank you.
      01-17-2022, 09:46 PM   #14
Cincinnatus
Drives: 2013 M6
Loving the 21" rims. What kind of money are we talking about?
      01-19-2022, 06:33 PM   #15
richlandforged
432
Pricing always accurate on our website, but our fully forged 21" setups start at $2,939.00 depending on finish option...
      02-09-2022, 08:23 AM   #16
richlandforged
432
We have an exciting development on the 20x11.5 rear option! We now have capability of producing a 20x11.5 et22 option, improving OEM stance 10mm, which will provide nice compatiblity with 305 and 315, and even 325 at the extreme. Configuration option is now available on our website!
      02-28-2022, 05:19 PM   #17
NYBulldog
Specialist
1310
Drives: Nikes
Holy crap I'm going to need these for my E63 M6
