      12-28-2021, 04:55 PM   #1
TomM6
TomM6's Avatar
Drives: F12 M6 individual
Catted Downpipe question
If I was to add catted Supersprint or Fabspeed cat downpipes to my car with the M Performance Acrapovic exhaust, would I still need to add a tune to eliminate CEL codes? And if I do not add a tune would I see any performance improvement?
Thank you
      12-29-2021, 12:50 PM   #2
Mhaus
Drives: 2013 M3
I had the fabseed highflow catted downpipes, and you will have a CEL but not all the time. It usually comes and goes so yes if you want to not have it you will have to code it out with something like bootmod 3. In regards to peformance you will see a gain as the turbos spool up more freely abd faster and the ecu will see this and adapt the f/a ratio and timing to accomodate. I went with fully decatted downpipes because I am stage 2 tuned. Just fyi though with the high flow cat downpipes thw fuel smell was almost none existent except when you get on it vs the fully decatted you will def smell it more all the time. Hope that helps.
TomM674.00
      12-29-2021, 03:38 PM   #3
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [0.00]
2009 Honda Civic  [0.00]
Thank you
Going off the below, if Fabspeed throws a CEL every now and then and you don't want to deal with that, I'd look into the Active Autowerke downpipes, they won't throw a CEL as they are denser, but not by much.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
TomM674.00
      12-29-2021, 07:54 PM   #4
TomM6
TomM6's Avatar
Thank you
I will look at those then, thank you for the info
      04-05-2022, 03:59 PM   #5
15Geez
Drives: BMW M6 Gran Coupe
Hey TomM6, I'm also in the DMV area (VA). I was wondering which route you ended up going regarding the catted downpipes. Did you purchasing them?
      04-05-2022, 06:30 PM   #6
BlaqDynamite6
Drives: BMW M6 F12
Thank you
I’m in the (D)MV area as well and was thinking of going catless w/stage 2 tune on my F12. From what I’ve read, you’ll need a tune to eliminate the CEL
TomM674.00
      04-06-2022, 07:34 AM   #7
TomM6
TomM6's Avatar
Thank you all, I decided against it as I am happy with the car as it is and will just enjoy it!
