      01-14-2021, 04:40 AM   #1
MARKPRIOR
156
Drives: 2017 M6 GC
Pics wanted - F06 with 10mm(F) 12mm(R) spacers & 20mm Drop
Anyone have any pics with stock wheels (433) but more the stance im after shots of
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5,
Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff
      01-14-2021, 09:40 AM   #2
LJohnson32
LJohnson32's Avatar
I have the spacer setup without the drop -- plan to do KW HAS come springtime as lowering the car in a Minnesota winter doesn't make much sense.
I have 343m wheels as well instead of 433m but if you still want photos I can take some at some point.
Desired drop for me will be somewhere in the 20mm range you're mentioning, probably 20mm front 15mm rear since the front seems to sit slightly higher for some reason
      01-15-2021, 08:19 AM   #3
MARKPRIOR
156
Drives: 2017 M6 GC
Yeah shoot some up please
thanks
      01-15-2021, 10:51 AM   #4
LJohnson32
LJohnson32's Avatar
thanks
Here's a few photos I was able to find. Snow tires on doesn't help as they're 255 width front and 285 width rear so there's a bit of stretch. Should be noted that my summer tires are 265 front and 305 rear, so the gap you're seeing at the back fills out much better. If you plan to stick with 295 rears you could probably get away with 15mm spacers at the back. Hope this helps somewhat.
