09-07-2020, 09:34 PM | #199 |
Rep 59
many thanks. i was successful in updating 2012 f10, 2015 f83 and f82. worked great. on the fsc gen tool - noted that the 2021 maps were not listed in drop down, so selected 2020 - and the key worked.
09-09-2020, 03:21 PM | #200 |
Rep 269
Drives: ///M6 GC
Glad to hear but surprised the 2020 key worked unless you selected the lifetime code which would explain it.
09-29-2020, 02:44 PM | #204 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
Shout out to BadSeed! Thanks for being valuable contributor to the forum and for your patience. Appreciate all your help.
BadSeed158.00 |
10-16-2020, 04:03 PM | #205 |
Rep 2
incorrect map code
Hi, guys
I have successfully pulled the FSC file Successfully generated map code plugged in FAT32 usb and started the update but when I input the map code it says it's incorrect. Any ideas why would that be? I tried both, Lifetime and not. same result. ////////////////// Update I tried installing 2020-1 map and it worked. Afterwords i updated to 2021-1 and it worked!!!! Last edited by dusek2; 10-18-2020 at 08:37 PM.. |
10-17-2020, 02:48 PM | #206 |
Rep 2
Could anyone help me to get a fsc code? I downloaded the maps, but I'm not familiar with the code generation process, even looking at the extremely well detailed process from @badseed.
My vin 0S17917 Map Next North America 2021-1 I don't have ENET OBD cable. Appreciate if anyone can help with more details for a dummy. Thanks everyone! Last edited by fabriciosc; 10-17-2020 at 04:54 PM.. |
10-18-2020, 08:36 PM | #207 | |
Rep 2
BMWAiCoder 4.6
Try out this app. Its really easy to use BMWAiCoder 4.6 https://www.car-auto-repair.com/how-...or-navigation/ |
10-23-2020, 05:03 PM | #208 |
Rep 359
Unable to download second file, when my connection drops mid-download or almost done it is unable to resume - happened 4 times already
01-23-2021, 09:59 AM | #211 |
Rep 93
Update prompt not showing up?
I have an NBT with 2016 maps on it and I'm trying to update it. I have a 32GB flash drive with 2020-1 maps loaded in it. When putting in this flash drive, the prompt popped up right away. But once I try the 2021-1 maps, nothing happens. This is using the same exact flash drive, nothing changed but me deleting the 2020 maps and replacing it with the 2021 maps downloaded from here. I unzipped everything properly. Any idea why this is happening? |
seansimsneill15.00 |
01-25-2021, 06:42 PM | #212 | |
Rep 49
Drives: 2016 535I 2000 528I
2016 535i
2001 530i |
02-15-2021, 11:47 AM | #213 |
Rep 2
How did you fix it?
03-15-2021, 09:41 PM | #214 |
Fueled by Recycled Dinosaurs!
623
Rep 1,163
Drives: F06 M6
TY for the contribution!
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vision, CCB, RKAutowerks Forged Rods/Pistons & E85 DI Exhaust Cams,Carbon Fiber CAI & Billet Diff Brace, Infinity Design CF Turbo Inlets, Swaintech Coated DPs, Mishimoto Oil Cooler, JB4, XHP S3 Flash, Bootmod3
03-30-2021, 07:08 PM | #215 |
Rep 2
Help please.
I downloaded the two sets of files onto a 32GB USB. When I get to this step (part 5) , I fail... 1. Extract BMW_CIC_FSC_Generator.exe from the ZIP file 2. Open BMW_CIC_FSC_Generator.exe 3. Select OK to download Lookup.xml file (computer needs internet access) 4. Select OK then close and open the program again 5. Select NBT then use Browse button to select FSC file. I select CIC here (2013 X5), but where is this FSC file supposed to be located? I’ve tried more than ten times in the last two days. Where am I going wrong? |
04-20-2021, 04:02 PM | #216 |
Rep 36
I keep getting failed disk full message =/ am I doing something wrong?
my HDD is no where near full, can someone send me a fresh link to download the 2021 NA NEXT 1 and 2 map? |
05-01-2021, 08:13 AM | #217 |
Rep 1
Would love the links to the maps and the FSC generator.
I have a NBT Evo system needing the Australia maps if that's possible. Thanks in advance and love your work! |
05-24-2021, 09:44 PM | #218 | |
Rep 10
I just finish upgrading my F25 2015 tonight. It also spent 1 hour to load the 2021 map |
06-04-2021, 03:16 PM | #219 |
Rep 1,246
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Thank you for this!
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
06-18-2021, 10:07 PM | #220 |
Rep 43
Through trial and error, I found a solution why many USB drives don't work despite FAT32 formatting.
Many drives are seen by the PC as "Local Drive" in "My computer", as if they were backup hard drives, not portable memory sticks. After inserting the USB drive into your car and getting a message to update it, an error message then says to insert the USB drive, and you can't get past it. The solution is actually to use a USB drive that is recognized as "USB Drive" in "My computer". If it shows up as Local Drive, your car won't see it as a USB drive either. The solution is to get another USB drive. I believe it has something to do with windows compliance standards, whether your memory stick shows up as USB Drive or Local Drive. |
