08-19-2019, 11:13 AM | #1 |
Rep 116
help, bluetooth connected but won’t play
My phone has been paired to my car but it wont play music via bluetooth. It will accept phone calls thru bluetooth but wont play any music from any of my music apps. Anyone experienced this? What you do to fix it?
FYI I had my car coded last year |
08-19-2019, 12:59 PM | #2 |
Rep 187
Tried deleting the phone and re-pairing with the car to ensure the media option is also selected?
08-19-2019, 06:13 PM | #3 | |
Rep 92
Thanks
Vehicle Diagnostics and Coding ISTA ESYS CarPlay Activation Sat Nav Map Updates SLI FSC |
08-20-2019, 09:38 AM | #4 |
Rep 7,484
If you can see that music is playing (by a time count etc) but you don't hear anything...try turning up the car's VOL knob...after turning up the volume on your device.
Bluetooth doesn't seem to play at the same volume as the radio and music uploaded to the hard drive. If you do turn up the car's VOL...remember to turn it down when before going back to the car's radio etc. Also, sometimes I have to have the app on my phone playing prior to connecting to the car...so try that, too.
08-20-2019, 07:15 PM | #5 |
Rep 116
I tried deleting and repairing, didnt work. It says “Not Connected” even though i can make and receive phone calls thru bluetooth. I usually turn the car off and on and it will work but this time its not working.
I’m using usb port to play music. Hard drive and CD stored music works fine |
08-21-2019, 03:11 AM | #6 | |
Rep 92
08-21-2019, 09:08 AM | #7 | |
Rep 7,484
Bluetooth (telephony) is different than Bluetooth music streaming (A2DP)...and you can tell by little icons in iDrive if your device is set-up for one or both capabilities. When you pull up the iDrive screen that shows your phone's connection to the car...are both icons illuminated? (see image below if you're unsure of what is being referred to) Also, what are your media options...when you decode your VIN what option codes do you have for media? I believe you need 6NF to stream music from your phone. If you only have 6NL...this may be the reason music streaming isn't working:
08-21-2019, 03:55 PM | #8 | ||
Rep 92
