      12-20-2018, 08:41 AM   #1
Pure Adrenaline
Drives: 2014 M6 GC CP
Dyno results
The local car club had a dyno day so I put the M6 GC on a dynojet. Factory stock down to the air filters, 55k miles, DCT, ZCP.
541 hp, 461 tq at the wheels on the first run which was also the best. Assuming 12% drivetrain loss, that's 615 hp at the crank. I was expecting around 500-520 rwhp so I was happy. Just thought I would share.
      12-20-2018, 05:13 PM   #2
kong24680
Drives: Silverstone Metallic F06 M6 Gr
91 octane?
      12-21-2018, 05:14 AM   #3
Novipec
Germany
Drives: M6 06/2015
Mine - stock, 93 octane, only good software
      12-21-2018, 06:18 AM   #4
TomM6
TomM6's Avatar
Drives: F12 M6 individual
So what was your HP and torque ? Your picture is blurry
      12-21-2018, 07:44 AM   #5
Pure Adrenaline
Yeah, the resolution isn't the best, sorry. I had also typed it out because of that.
The first run yielded 541 hp and 461 tq. The subsequent runs yielded lower numbers (524 hp/457 tq; 532 hp/457 tq).
      12-21-2018, 07:45 AM   #6
Pure Adrenaline
Originally Posted by kong24680 View Post
91 octane?
92
      12-21-2018, 12:10 PM   #7
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
You run on 93?
What model?
CP?
880 Nm tq
      12-22-2018, 01:34 AM   #8
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
your whp is ok but the Tq is low...
      12-22-2018, 02:14 AM   #9
Novipec
Germany
Drives: M6 06/2015
Originally Posted by Havy View Post
You run on 93?
What model?
CP?
880 Nm tq
2015 M6, no CP, it runs on 98 Octane Europe, equal 93 in US, ECU flash.
880 Nm are 649 ft lb
The engine could be more, but the clutch is the limited factor (got already a new DSG, clutch and the differential becaus of shavings in the oil).
Just cutted the torque to 600 ft lb, so I can sleep better in future
      12-22-2018, 05:45 AM   #10
SE7EN335
Drives: 2022 M3 XDrive, 2023 IX M60
Wait what? You got a new DCT from slipping clutches on a stock tune?
      12-22-2018, 06:35 AM   #11
Novipec
Germany
Drives: M6 06/2015
Complained a rough clutch when the car was cold, BMW decided to put a new clutch in it, after removing the oil pan they found some fine shavings in the micro filter, so i got a complete new transmission including clutch.
The differential was changed 1000 miles later, because we checked the oil level and found also lot of shavings in the oil...
After all was set up new, I did Stage 1.
      12-22-2018, 08:06 AM   #12
Pure Adrenaline
Factory rating at the crank is 500 lb/ft, so I'm not sure if 461 is at the wheels is considered low.
