      09-11-2021, 07:19 AM   #1
ikenjoku7
ikenjoku7's Avatar
Drives: 08 e92 335i
2014 f13 M6  [0.00]
Hey guys. So I went on a trip out the country a while back and I came back to my driver side soft close motor failed. Another fun thing my car does is unlock and itself whenever I stand by the passenger side of my car too long. It'll also sound like my gas cap is constantly trying to unlock itself. I did some research and found threads for both issues but they don't seem related so I have some questions before I go about repairing.
1. The soft close motor on the driver side is the only one not working. BMW of midtown in Houston were quick to tell me that I need to replace both sides but that doesn't even make sense. Can I get away with just going on eBay and getting just the driver side motor? Shoot I'll do the install myself if I can find the tutorial on how to remove the door panel.
2. It seems that the car unlocking itself is a issue with the passenger side CA door handle. Am I buying just the handle or the whole assembly? Can I simply just buy another door handle or do I need to get it coded? Could this be related to my driver side soft close motor failing?
3. I'm pretty sure the CA door handle malfunctioning is also killing my battery but I have a 14 with 65k miles on it. For what it's worth I had no battery issues until this started happening. Should I go ahead and replace the battery too? Take it to get recharged? Or can I just leave it alone?
      09-11-2021, 11:57 AM   #2
Qsilver7
Qsilver7's Avatar
Here some thoughts on what you’re asking. Sorry I don’t have definite answers…but just somethings to consider.
1. Before spending money on a new SCA (soft close actuator)…just this past week…I saw a video (on youtube) that was brought up on another forum about their soft close actuator…the video showed how a non-working SCA was fixed by replacing the screws that secured it to the door. When they removed the door panel… 3-4 screws that held it in place had rubber washers that had degraded….and the SCA could be moved back and forth. When they replaced the screws, the SCA started working again. Unfortunately the video doesn’t actually say WHY the SCA stops working. It was something I put into my mental Rolodex to check before replacing the SCA. So just sharing that tip…it may or may not work…but replacing the 3-4 screws is a lot cheaper than replacing the SCA. So check to see if your SCA is loose.
EDIT: Just went to YouTube and typed BMW soft close replacement to see if I could find the video referenced above…it came up as the 6th result on the list of videos. It was a 7 series that was being worked on but the basic design architecture is similar for the 6 series…so again, check to see if the SCA is loose and has similar securing hardware…you may be able to save some money and easier fix if you find a similar fault:
2. CA (comfort access) door handles is a common repair fix across multiple BMW platforms. The handles are NOT coded…and yes, they can drain the battery. A simple google search for replace BMW comfort access door handles should give you some ideas/suggestions etc on how to proceed.
3. Yes, again, CA door handles can drain a battery. How bad can it get? Any deep discharge of the battery lessens its life span. Do you have a trickle charger? If yes, then keep it hooked up to the dedicated jumpy start terminals in the engine bay to prevent the battery from going into a discharged state. Again, repeated deep discharges damages the battery and shortens its life span. I good trickle charger/battery maintainer (this is also a much discussed topic that a simple search will give you some good advice on what to look for etc) can help you keep your battery in working condition and lengthen its usable life. Or you can take your chances and have a battery that might leave you stranded if left in a situation that it can’t handle (extreme heat or cold spell).
