      07-16-2021, 12:37 PM   #1
MARKPRIOR
156
Drives: 2017 M6 GC
Oil pan removal, can this be done in situe?
As above can removing the oil pan be done with the engine in, without removing subframe etc..?
Thanks
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5,
Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff
      07-16-2021, 12:44 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
Yes:
Necessary preliminary work:
Drain off engine oil
Lower front axle
Remove lower oil sump section
Remove oil pump.
Release supply/return lines on oil filter
Release holders of supply/return lines on oil sump
Detach plug from oil pressure switch
Unclip wiring harness on oil sump
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
Mdriv3r148.50
      07-16-2021, 03:53 PM   #3
MARKPRIOR
156
Drives: 2017 M6 GC
Thanks, any idea what parts are needed ? Gaskets etc.. much appreciated
      07-16-2021, 04:49 PM   #4
arucano
arucano's Avatar
See if this helps. You can also look at REALOEM dot COM.
      07-17-2021, 03:51 PM   #5
MARKPRIOR
156
Drives: 2017 M6 GC
Appreciated
