12-18-2020, 01:44 PM | #1 |
Rep 5
640i bootmod3 burble not working
Hi
I got an issue with bootmod3 and its burble fuction. It simply refuses to work. First my car: bmw 640i, N55, stock, 07.2011, from switzerland I've been going back and forth with customer support and yet have to succeed. Im trying to flash stage 1, 91 octane. They gave be access to AGG tune and that didnt work either. No matter what settings I choose, how long or how agressive it doesnt burble at all. So they just told me to check if ASD (active sound design) was deactived via coding before. I never did any coding on it but checked either way. However in bimmercode and another tool I tried do NOT list the ASD module. Its completly missing. I tried activating and deactivating ASD on bootmod3 itself, no change. I never get any errors. Everything seems to flash just fine. The main reason I got bootmod3 is the burble. And I even asked a year prior (just bought it this black friday) if it works on my car and they said it would be no problem. Anyone know the issue? Is it because of missing ASD? |
12-18-2020, 02:33 PM | #3 |
Rep 48
I have MHD. I have to put it in manual mode in order for the burble. I have my min. rpm set to 1800 and max set to 5800. I don't know if you have an option to set how aggressive. I have mine set to soft. I wanted mine to sound more stock.
12-18-2020, 02:40 PM | #4 | ||
Rep 5
Worst case, I'll try refund :/ Quote:
I also asked them prior if it would work on my car so... You also have a 640i? Was it clear that it would only work on manual? |
12-18-2020, 10:14 PM | #5 |
Rep 48
I was debating wether I should do MHD or Bootmod. However BM3 was cheaper thanks to usd currency and black friday offer.
I also asked them prior if it would work on my car so... You also have a 640i? Was it clear that it would only work on manual?[/QUOTE] Yes I have the 640i. It wasn't working for me on auto but I noticed today when it was sport mode and auto, it had baby burbles when I was slowing down lol. It would only do it sometimes. In manual mode, it would burble all the time and longer. I prefer it to burble in manual mode only because I don't want to burble all the time. I didn't want to burble on quiet streets like in my neighbor hood or if someone has their car window open. I have my duration set to 1.3s m and 2s on s. I don't if this makes a difference, I have the M6 exhaust with a custom X pipe. Btw, I got mine on black friday also. I paid $464 and includes all maps/stages. I was debating on BM3 but I noticed it was $50 more the maps. I thought the MHD was cheaper? It also had maps that utilized the xHP transmission flash which I bought on bf. |
12-19-2020, 02:16 AM | #6 | |
Rep 5
What year is your model? |
12-19-2020, 07:52 AM | #7 |
Rep 1
Do you have the stock exhaust on your car? I have a 640i and installed BM3 shortly after I got the car mainly for performance benefits, but it wasn’t till after I got a custom exhaust work done that the burbles worked and it’s only in sport or manual mode. I think those massive stock mufflers contain the burbles
12-19-2020, 01:58 PM | #8 | |
Rep 5
The customer support also told me a year ago that it only works in sport mode (not comfort) on the 640i. But yeah, I have yet to hear something. |
12-22-2020, 01:16 AM | #9 | |
Rep 48
01-01-2021, 04:10 PM | #10 | |
Rep 5
Hey guys so I received a new test map from the support and burble works now.
However its active all the time. I cannot toggle it off depending on what mode Im on. I told them it works but not how its supposed to. My car burbles on all modes at the same setting. It should only do so in sport and comfort mode. Quote:
I mean I also specifically asked a year ago if my car supports that and they said yes. Oh well I told them to try fix it or give a refund if its not possible. |
01-04-2021, 03:28 PM | #11 | |
Rep 48
I made changes to mine. I only have burble on when on Sport mode and at 1.5 seconds. I want it to sound stock. It's close but sometimes there's too much burbles. If I can find a good setting then I might enable it with comfort mode. Unfortunately I only make one change and stays like that for a week or 2 until I try another setting. I am not constantly trying different burble settings and I should, I wish I had more time. |
01-27-2021, 03:59 PM | #12 |
Rep 17
If we hook up the vacuum from the stock sport exhaust to an M exhaust (i have a M5 valved exhaust) will it have enough vacuum to actuate the valves? 640i only has 1 vacuum hose, M5 has 2.
