01-31-2023, 08:29 PM | #1 |
Rep 365
noisy blower motor on high
Hi everyone wanted to ask if anyone has experienced a noisy blower motor when in the highest settings. Sounds normal during lower speeds once you bump it up it becomes noisy behind the dash. Let me know if anyone has experienced this and if taking down the blower motor to inspect is complicated
02-01-2023, 07:19 AM | #2 |
Rep 60
hi,
taking the blower motor out is VERY delicate... if you want to ter it,open the bonnet (hood) at the back of the engine bay at the top there are 2 strenthening tubes,from under the windscreen plastic scuttle panel to each of the strut tops, first you need to remove the right hand platsic trim in the corner which buts up to the windscreen.then you will be able to remove that right hand strengthrnin tube which goes to the strut top. you will now see a large flat box type lid.approx 300mm x 200mm ish.there is a coarse filter foam on the front side,and an auc sensor..be carefull of the sensor,its fastner breaks eaisily..you need to remove the 4 torx screws that hold the big lid on. the coarse filter is worth cleaning, after you remove the big lid you will see the fan motor and the recirculate vent flaps..these vent flaps just sit in position and are not fastened in ! also at the end of the vent flaps are drive gears which if removed must be put back in correct position or the vent will not fully open or close. you can see the ends of the motor shaft,it might be worth lubricating the bearings (as long as they are not sealed bearings)with light oil.dont put too much oil on as you will smell it inside the car also end of line resistor is in there.. check the fan blades for any scuff marks where it might be catching.. do not operate the fan with the box lid off ! the only other possible cause of the noise is something might have been dropped into an air vent and the fan on low isnt powerfull enough to pick it up but the fan on high might be. also worth taking the lid off the pollen filters box and removing the pollen filters then turn the fan up..the pollen filters are replaced for maintenance and as it gets disturbed it might not have been re fitted correctly. |
02-01-2023, 08:12 AM | #3 | |
Rep 2,907
02-01-2023, 08:24 AM | #4 |
Rep 60
the only place the blower motor sucks air in is through the coarse faom filter on the front edge of the heater motor box..this foam filter wouldnt let anything through it that was big enough for a naked eye to see..anything dust wise that does get through is stopped by the finer pollen filters...there is no other point in the system at which a foreign body could get in apart from dash outlet vents.
it could be the motor itself but i would have thought it would squeel at all speeds..it is possible though..i guess the higher the milage the more likely. if you do take the motor out to replace it take some pics with your fone and use tippex or marker pen to mark the drive wheels ect. good luck. |
02-01-2023, 09:18 AM | #5 | |
Rep 7,484
You may want to check to see if that coarse filter is starting to disintegrate and is the cause of your issue. The cover w/coarse filter is #1 in the diagram below: There is a great video on YouTube that shows how to access and replace this coarse filter. The video is for an f01 7 series...but our F06/f12/f13 HVAC blower is set up the same way. I"ll try to see if I can find that video and post it here. EDIT: I found the video (which is by an old friend from the e38 Bimmerboard forum days...Edwin from the Netherlands). He also recorded the sound coming from the blower at the beginning of the video which may help to determine if it is the same sound the OP is hearing...then goes on to show how to access and remove the cover:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-04-2023 at 07:12 AM.. |
02-07-2023, 12:23 AM | #7 |
Rep 106
Yep. I did this 2 weeks ago. Same annoying noise after you bump up fan to 4+. Took the blower apart and low and behold, there was a single dry leaf sitting in the blower spindle. Put it back together and it fixed the issue. Leaf got in there cause there was nothing left of the shitty filter. Picked up a new housing lid from dealer that comes with a redesigned filter (the new one is white). Yet to install it though.
02-08-2023, 06:05 PM | #10 |
Rep 7,484
Any of the online part database sites can quickly be accessed to give the part number for the cover w/coarse filter. It will be found in the HEATER/AC diagrams.
DerBosewicht112.50 |
02-22-2023, 06:12 PM | #12 |
Rep 113
Here is a video on a F07/F10 where they removed the entire blower housing. I am glad I watched this one, because it shows the location of the blower resistor (bottom of the fan housing). I was told it was under the dash, and would have taken bottom of the dash apart to get to it.
I wish I had known this before getting in there over the weekend and changing the fan. It would have saved me some time to do it all at once when the resistor comes in next week. But I can do the job in 30-40 minutes now. Just goes to show how much the stealers make off repairs. |
03-01-2023, 08:12 PM | #13 |
Rep 113
Did the swap on the fan resistor after work today. Took 33 minutes. from me leaving my desk (office is in my house) until I finished washing my hands.
