      09-08-2021, 11:29 PM   #1
dannytacu
Drives: m6 f13
help please
so i have some problems with my f13 m6 i changed one of the injectors and after that i deleted all the adaptations of the car i don't know why i did that
now i have this codes
164042 intake camshaft 2 -installation faulty
164043 exhaust camshaft 2- instalation faulty
120408 charging pressure control-switch off as consequence
120908 charging pressure control-switch off as consequence
please help
      09-09-2021, 02:59 AM   #2
M6Roar
Drives: '14 M6GC
not sure if this would help but did you do the "Learn Valvetronic limit position" after deleting adaptations? do the VANOS also
      09-18-2021, 07:26 PM   #3
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
Did you add the calibration info of the injector. I am out of the country right now and don't have the specific steps but when changing injectors you have to update the ecu. Also, did you verify the proper injector type IIRC there is eu5 and eu6.
      01-20-2023, 02:28 AM   #4
overcrash94
Drives: M5 f10
Hi, did you found the problem? I have the same with my m5 f10.
Thank you.
      03-05-2023, 11:48 PM   #5
voliyavor
Drives: bmw e70
please help
Hello what was wrong the car did you fix the problem
I have the same problem with my bmw
Thank you in advance
