      10-26-2018, 05:19 AM   #23
Adrian01702
Drives: F06 640i
Originally Posted by maron View Post
In my country
Used units may be obtained cheaply.
My total cost is about $600 with all DIY done.
If you have CIC installed, flash to ZGW02
Or you need a retrofit adapter.
Other complicated wiring work will be necessary.
Can you explain the "complicated" wiring?
Would buy an retrofit adapter, with nav activation.
Are there any kind of problems with this retrofit?
Btw no need for touch for me Just the NBT EVO
Thanks!
      10-28-2018, 09:12 AM   #24
maron
maron's Avatar
74
Drives: E60&F06
If you purchase a retfit adapter, it will be listed in the purchaser's instructions.
You confirm the wiring of the CIC and EVO quad connector.
should also check the wiring of combox ....
      11-02-2018, 11:00 AM   #25
FBMWWINS
FBMWWINS's Avatar
604
I came across a headunit high 2 which is touchscreen and has HW version 4.1. It is an HB B210 unit complete with DAB, TV function and all. I'm considering to retrofit it in my F32 as my F06 already has EVO.
Does anybody know if HW 4.1 units are automatically NATIVE ID6 units? Or could it still be an ID5 one? If I'm to spend a 1000 or more Euro for a complete set (unit, display, controller), I'd rather get a native ID6 one if possible.
      11-04-2018, 07:07 AM   #26
maron
maron's Avatar
74
Drives: E60&F06
If its F series unit, I think that its only the difference in coding.
When I coded VO in 2018, headunit showed ID6
      11-04-2018, 12:45 PM   #27
FBMWWINS
FBMWWINS's Avatar
604
The 4.1 HW unit I saw is from a G11 accident car from October 2017. Being touchscren it might very well be a native ID6 unit but I'm just not 100% sure. I know you can code an ID5 unit to ID6 light which will give you graphically the same menu as the newer ID6 units.
      11-05-2018, 03:43 PM   #28
FBMWWINS
FBMWWINS's Avatar
604
Thinking of retrofitting the above on my F06 for native ID6 and touchscreen functionaility. However I'm combatted between different screens such as:
G11 and G12 models - Kyocera screens made in Thailand
G30, G31, G38 and F90 models - LG Electronics latest screens July 2018 batch
All are 10.25" but I wonder if there is any difference in quality or any improvements? Pricewise they go for about the same. The shape though seems to be different thus I'm thinking which one would fit better as a replacement of the original F06 factory display?
      11-05-2018, 10:50 PM   #29
maron
maron's Avatar
74
Drives: E60&F06
First of all, it cant be installed with the 6 series plug-and-play.
Disassemble the other car's monitor and install it.
I think that it is impossible on the structure of G11 monitor.
Disassemble and install the 10.25 inch monitor such as G30.
its best to combine it with pre LCI monitor
      02-11-2019, 04:27 PM   #30
Tungmeister
Tungmeister's Avatar
11
Drives: 2012 E92 330d
I'm looking to do this in my f06, does the black ATM Module provide the GPS via its pink connector? If so does this mean that the blue GPS connector from the old headunit is no longer used?
      03-11-2019, 01:56 AM   #31
maron
maron's Avatar
74
Drives: E60&F06
Yes ATM Module provide the GPS via its pink connector
My unit didt have a blue GPS connector.
https://minkara.carview.co.jp/userid...ote.aspx#title
      03-13-2019, 12:56 AM   #32
maron
maron's Avatar
74
Drives: E60&F06
Each one works the same way.
But to disassemble the touch monitor
The F15 touch monitor is suitable.
If you use the G series touch monitor, you will need to cut the glass.
FBMWWINS603.50
      03-15-2019, 05:49 PM   #33
hugo_nz
hugo_nz's Avatar
3184
2022 BMW IX  [0.00]
How did you modify the F15 display for the F12? I am about to buy a retrofit kit, but BimmerRetrofit want to supply a G30 monitor for the kit and I do not want to modify the dashboard to make it fit.
      03-15-2019, 07:59 PM   #34
maron
maron's Avatar
74
Drives: E60&F06
Look at the post # 3 image.
Image 1
Disassemble the F15 touch monitor.
And I cut the top 3mm with a glass cutter (I corrected the height later)
Image 2
Fix the touch monitor with epoxy adhesive to the monitor cover of the pre-LCI.
Image 3
Image of touch monitor fixed from the back
      03-15-2019, 08:14 PM   #35
maron
maron's Avatar
74
Drives: E60&F06
ITS retrofit《Intelligent Transport Systems》
      03-21-2019, 02:12 AM   #36
Thewrench86
Drives: E92 \M sport. F06 640d M Sport
https://www.bimmer-tech.net/shop/bmw...ation-retrofit
This seems like a good option as well with them supplying screens and everything needed. They also uploaded a video about the retrofit in a 14 M6. Looks really good.
      03-21-2019, 02:43 AM   #37
hugo_nz
hugo_nz's Avatar
3184
2022 BMW IX  [0.00]
Their retrofit is non-touch screen only. Also, if retrofitting to a pre-lci F-series you will lose HUD. Only earlier HW versions of NBT allowed HUD functionality to be retained.
      03-21-2019, 02:45 AM   #38
Thewrench86
Oh wow well that was very useful to know thanks. I guess that's not really an option for me now.
      03-21-2019, 03:33 AM   #39
hugo_nz
hugo_nz's Avatar
3184
2022 BMW IX  [0.00]
No problem. I have ordered an NBT retrofit for my 650i, and the main reason I am not getting NBT EVO is because I want to keep the HUD. I abandoned iPhone a long time ago so don't care much for Apple Car Play.
      03-21-2019, 07:20 AM   #40
Thewrench86
I currently have nbt system but wanted the Evo id6 just for screen mirroring really for my android device and better gui. I also prefer the look of the newer screens
      03-21-2019, 10:42 AM   #41
elvisisdog
Drives: F06 MSport 2013/09
Hugo_nz - where did you find out about the HUD not working with nbt Evo head units? I was thinking of upgrading my nbt to Evo but couldn't live without HUD.
      03-21-2019, 01:10 PM   #42
hugo_nz
hugo_nz's Avatar
3184
2022 BMW IX  [0.00]
You can buy the glass screen for nbt too btw: LINK
      03-21-2019, 01:11 PM   #43
hugo_nz
hugo_nz's Avatar
3184
2022 BMW IX  [0.00]
LCI cars or those with nbt from the factory shouldn't have a problem with HUD functionality when retrofitting Evo.
      04-21-2019, 08:56 PM   #44
Pano6
Drives: BMW 640i
How do you find out if you have the LCI version or not? I've been looking all over on retrofitting this and seems quite a confusing thing due to all the different models.
