08-02-2018, 06:18 PM | #1 |
Rep 40
Coding out adaptive function of the LED headlights?
Is there anyone who knows how to code out adaptive function of the LED headlights?
As in, I can still put them on auto mode, but they no longer turn with the steering. Dealer has been unable to do it, most "coding specialists" don't seem to know how, except one who said it'll be multiple parameters and asks 50 EUR an hour to "research" into it. |
08-05-2018, 09:16 AM | #3 | |
Rep 7,484
BTW, isn't this feature deactivated when you turn the dial to the regular ON position vs the AUTO on position? EDIT: just checked the owners manual and yes...adaptive light control only operates when the switch is in position 3...when position 6 is selected...the adaptive feature where the lamps turn in conjunction with the steering wheel along with specific speed criteria...is deactivated:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-05-2018 at 09:35 AM.. |
08-05-2018, 02:16 PM | #4 | |
Problem Solver
113
Rep 416
08-05-2018, 02:26 PM | #5 |
Rep 659
Had this with my 530d, I replaced the std halogen with ultra white bulbs, didn't make much lighting difference but didn't look awful anymore
DerBosewicht112.50 |
08-05-2018, 04:55 PM | #6 | |
Rep 40
As result, the left headlight goes out as soon as it turns left with the steering. The headlights function without problem if turned on manually. After hours of diagnosis at the dealer, they recommended to replace the whole headlight for 2000 EUR + VAT. If I can deactivate the adaptive function, I could at least have my headlights on auto mode again. |
08-05-2018, 07:35 PM | #7 | |
Rep 7,484
08-06-2018, 01:51 AM | #8 |
Problem Solver
113
Rep 416
thats good to know, that the bulb can be replaced with a bright white.. i am look into that.. then i will use adaptive feature again!!
You need people like me so you can point your f*ckin' fingers and say, "That's the bad guy". "Das ist der Bösewicht". |
08-06-2018, 01:55 AM | #9 | |
Problem Solver
113
Rep 416
2000 Euro = $2236 US please tell me that is a mistake.
08-06-2018, 06:56 AM | #10 | |
Rep 40
2000 EUR PLUS 21% VAT. And for the part only No fitting/coding included. I don't mind paying this amount for something serious, but being able to use auto mode again.. I turn them on manually now, but it doesn't feel quite right in a 6er. Quite frustrating I'd say. |
08-06-2018, 08:04 AM | #11 |
Rep 7,484
At those prices...I'd probably keep an eye on breaker yards and see if a left headlight shows up. That could be a possibly less expensive solution.
08-06-2018, 08:06 AM | #12 |
Rep 544
My car has two modes:
Sets in the garage ,,, or I drive it..... Like my dad aways said (keep it simple stupid )
1."Luck" is an excuse for people that have failed at their mission to do something! (Allan McNish)
2. I’m not an (EXPERT) I’m just here with an opinion. So don’t hate me. (lukej) |
08-06-2018, 09:19 AM | #13 |
Rep 40
I've seen a thread about where other people are having the same issue on the 6. You never know if the used headlight you purchase have the same issue tho.
08-06-2018, 08:39 PM | #14 |
On the hunt
37
Rep 257
Drives: 2016 MB F06 650i RWD
same price in the US. one of my headlights threw a code when the car was in the shop...had to go to the dealer and they ended up replacing the entire thing and it was that expensive (luckily I was covered under warranty)
