01-16-2022, 07:29 AM | #2 |
Rep 77
01-16-2022, 11:52 AM | #3 | |
Rep 49
Just did it again, took off from maybe 60-90, came on and then gone in 5 seconds. Someone mentioned a sensor, maybe from down pipe getting hot? I have no idea. So maybe I need a transmission cooler or ssp spec r clutches Just curious what the cause may be? Car is new to me so I’m open to suggestions Last edited by 20comp8; 01-16-2022 at 03:17 PM.. |
01-17-2022, 04:17 PM | #4 |
Rep 49
Called the shop, they said either clutch sensor or new clutches, making around 650 ft lb
Think I’m gonna bite the bullet and do ssp’s Sucks wanted to take it on a road trip It’s fine if I don’t drive it hard but I don’t wanna risk it |
01-18-2022, 03:21 PM | #5 | |
Rep 77
As a side note as well following the above as far as WOT will also save you from bending a rod in the lower gears…. Last edited by Mhaus; 01-18-2022 at 03:41 PM.. |
Kick 6285.00 |
01-19-2022, 02:43 AM | #6 | |
Rep 147
01-19-2022, 09:51 AM | #7 |
Fueled by Recycled Dinosaurs!
630
Rep 1,170
Drives: F06 M6
Look at Deka clutches as an option. There are folks on the 5 and 6 forums that have recently had some problems with their ssp clutches. The team at Evolve also started using deka. Clutches are in my future as well and I'll likely have my TCU tuned as well.
01-22-2022, 11:27 AM | #9 |
Rep 49
Getting SSP clutches. Not sure what the issue is here, but I feel better having them than not. Will also ask the shop about the tune. Anyone done a cooler on theirs?
01-27-2022, 10:52 AM | #10 |
Rep 742
Drives: '13 F13 M6, '94 JDM Supra 5MT
You can upgrade the pan, BMS sells a high cap billet model that should assist with cooling slightly.
