12-10-2016, 12:11 PM | #23 | |
Rep 556
The question I have is should I over inflate the tires? Should I use Sta-bil? If the snow is minimal this year, I could take the car out every 10-15 days and drive it for about 10 minutes. Do I need to winterize? I know that I do need to be careful as the PSS tires aren't rated for under 40 degrees, so I'm not looking to push the car in any way and will most likely just getting the car up to temperature for about 10 minutes. If there is snow/salt, I will most likely leave it parked for a good while. I'm just totally unsure what to do as it really depends on various factors (temp/precip). Anyone have anymore insight? |
12-10-2016, 12:22 PM | #24 |
Rep 3,968
I've stored my 1M for the last couple of years over the winter.
1. Never touched the tires, just parked it. Did not over inflate, but made sure they were at the right pressure. 2. Kept the Ctek on it the whole time. 3. Tried to fill gas as much as possible - never used stabil 4. On those nice days with no snow - after maybe a rain has washed all the salt away, I would take it out and get it nice and warm. I'm sure it was probably in the 30s or 40s when I did this. 5. Then put back with charger on until the next time. I probably only got it out once a winter. Today's tires really don't flat spot IMHO (and when they did, they were fine within a few miles) and the thought of putting stabil int he tank never sat well with me. Then again, I did try to drive it as much as possible to go through that tank of fuel come spring. I honestly think sometimes we over think this stuff
M3 Adjuster7909.00 963mw331.00 |
12-10-2016, 12:28 PM | #25 | |
Rep 556
12-10-2016, 01:29 PM | #26 | |
Rep 573
There is an argument that oil will not get around the engine due to it not being at operating pressure when idling but look at it like this, how many daily commutes start car, drive a short distance then sit in traffic idling for sometimes hours! Also, think of a generator or similar, it starts and idles forever ... I have a 1981 Honda generator and its still going. It's no different to starting in the garage and letting it idle. Get it warm do some light revs to get oil pressure up and leave it. |
12-11-2016, 05:09 AM | #27 | ||
Rep 3,957
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
ZPrime611.50 |
12-11-2016, 05:32 AM | #28 |
Rep 573
It was approximately! I said ensure the oil gets up to operating temp, which is the key bit, if it takes longer run it longer. Water obviously will get up to temp before oil. And 100 for me is 100 deg c, im from the UK
12-11-2016, 11:06 AM | #29 | |
Rep 3,957
12-11-2016, 08:10 PM | #30 |
Rep 2,736
Do not store your car on jackstands as mentioned earlier in this thread. Wheels / tires suspended for extended periods is not good for the suspension components.
Change oil and filter, add stabilizer, top off tank, park on carpet runners, over fill tires once at storage destination, close all windows, use trickle charger, move car a few inches every 3-4 weeks to prevent flat spotting. If there is the possibility of rodents, cap exhaust ends and put a big sticker on your steering wheel so you remember you did that. Two different thought processes on starting. I believe starting and running the engine until fully warm every few weeks. |
12-12-2016, 06:29 PM | #31 |
Rep 556
Quick question for those of you with CTEK chargers (4.3 MUS) and in cold weather...Do you use the snowflake mode for the winter? I'm not sure how many times it will get under 41 Degrees being that winter weather can vary in Pennsylvania (It will definitely get that cold outside and on extremely cold days will get that low in my garage). What I don't understand is that the Automobile mode is rated for the same low temperature -4 Degrees Fahrenheit and goes up to 120 Degrees, while snowflake mode goes from -4 to 41. This would be the first time I've used this charger, so just looking for any insight.
Edit: I looked quick on Realoem and it appears as if the M2 has an AGM battery, so I'd use the snowflake mode regardless of temperature, so it seems. Can anyone confirm? I'm probably going to throw it on the charger here in the next few days as it looks like its going to get pretty cold. Last edited by MTHRAR; 12-12-2016 at 08:50 PM.. |
12-12-2016, 08:25 PM | #32 |
Rep 126
Is there a science with plugging in battery tenders? I have never dealt with one and the last thing I want is to overcharge the m2 battery. I just purchased a Dellran battery tender before seeing this thread(dumb me) sorry if I sound ignorant but better to be safe than sorry!
12-13-2016, 02:30 PM | #33 | |
Rep 573
AYurch50.00 |
12-13-2016, 07:30 PM | #34 |
Rep 430
Drives: 2017 M2 LBB 6MT; 2012 328i 6MT
Here is what I received from BMWCCA.ORG
The winter storage blues https://www.bmwcca.org/forum/index.p...e-blues.11616/ |
12-13-2016, 07:58 PM | #35 |
Rep 37
E-Brake during storage.
I didn't set my e-brake, my car was outside for a few days with it on and you when I went to use it you could hear the snap of the brakes releasing after the car started rolling.
12-13-2016, 08:54 PM | #36 | |
Rep 126
2017 M2 LBB 6spd Executive Package (Delivered 12/1/16)
2016 Dodge Ram Sport 1500 (Daily) 2013 VW Golf R (Sold) 2007 Honda Civic Si (Sold) |
12-19-2016, 11:10 AM | #37 |
Rep 3,302
So far, I'm doing fine just packing my car in Road Salt and Ice.....LOL...heated steering wheel is very nice, sport plus in the snow is a must see.
Mike
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
12-19-2016, 11:32 AM | #38 | |
Rep 3,968
12-19-2016, 04:54 PM | #39 | |
Rep 573
I've done it for years without issue. I just lift up so the wheel is just off the ground and no more. |
12-19-2016, 06:12 PM | #40 | ||
Rep 3,957
01-02-2017, 10:26 PM | #41 |
Rep 2,445
Drives: 2022 M3 6MT
Mayhaps this will help:
http://www.m3post.com/forums/showthr...Winter+storage
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
10-31-2017, 10:09 AM | #42 |
Rep 430
10-31-2017, 06:07 PM | #43 | |
Rep 41
Drives: F87 M2 Long Beach Blue
I store all 16 race tires in the house over winter (much to my wife’s chagrin). I also wrap them as they disperse harmful vapor over winter. |
10-31-2017, 07:43 PM | #44 |
youtube.com/rodoabadtv
155
Rep 248
Drives: 2017 Dinan M2, 2023 X3MC
Instead of driving the car around whenever there's no snow or sale. I opted for a CTEK charger so I don't have to worry about it.
Thanks, doug_999 for suggesting the CTEK! This is actually my first time using a battery charger/tender. As someone who struggles following instructions [phew] this was easy! Last edited by P4rD0nM3; 10-31-2017 at 08:20 PM.. |
