07-15-2022, 09:08 PM | #1299 | |
Rep 685
07-16-2022, 07:10 AM | #1300 |
Rep 11,843
Drives: MY24 G01 AW Msport
07-16-2022, 08:53 AM | #1301 | |
Rep 1,543
Do you know that you have complete coverage from you irrigation? Where are the sprinkler heads located that water along the street and driveway? I wonder if there is a coverage issue in the middle of the yard and along the street/driveway. For example, my sprinkler heads that waters along the street are along the setback line (~15ft) from curb) so they aren't damaged if the city does roadwork. The drawback to this is that there is no other zone that overlaps watering along the street so the area my curb is susceptible to underwatering, particularly since wind will effect the throw of water. What do the dying (not the already dead) grass blades (front yard) look like? Color and any patterning on them can be clues. I also wonder if along the driveway to the mailbox might be insect related but can quite tell from the pix. I'm always paranoid about sod webworms and I think I see some webworm damage there but...the die off there could just be a Rorschach test to me. When did the grass here die off? Likewise, does the dying grass have a root system left? It's a little early for webworm this year but the color of the dead grass looks like it's from this year. For that horrible looking section...are there grass clippings there? I can't tell from the pic if you camera applied noise reduction to the picture or if there is a layer of something on top smothering the grass. There is quite a clump of dying, green clippings on the right of the picture against a foundation wall, though. Also, the way there is a dead streak coming from the high ground in the upper left of the pic that connects to the large, dead area is weird. Does anything drain to and collect there? This section in particular looks to require reno over seeding but if there is pooling that is causing the grass issue, that needs to be taken care of.
- Jeff
bosstones' flickr |
07-16-2022, 10:08 AM | #1302 | |
Rep 1,543
The real take aways is that, depending on weather conditions on a given watering day where you live, you need to adjust accordingly. Not a scorching but overcast day? You can get away with watering a little later. Not scorching but sunny? Meh...water earlier. Scorching and sunny? Better be done watering early. Water less frequent but deeper to encourage deep roots. As someone mentioned, watering more frequently but shallower (ie shorter duration) encourages shallow root development which leads to less robust grass.
- Jeff
bosstones' flickr |
07-16-2022, 11:37 AM | #1303 |
Rep 2,524
depending on your climate, that is a good way to get fungus.
colder temps + dark = fungus
07-16-2022, 11:44 AM | #1304 | |
Rep 2,524
that spot next to the fence, is it a high traffic area? almost looks like a path from the house to the fence. Looks like there is maybe some fungus/disease on the edges of the dead spots as well that is spreading. my recommendation is always to start with sprinkler coverage, then get soil tests done. take samples from the problem areas and send them in to one of the many soil testing companies. some will also test plants/grass to see if there is disease or something on them. From there, you have a pretty good path forward.
nyalpine907433.00 |
07-16-2022, 12:18 PM | #1305 |
Rep 4,821
There could be pests but watering schedule tells me there must be fungus / disease involved as well.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
nyalpine907433.00 |
07-18-2022, 09:59 AM | #1306 |
Rep 11,843
i did find few mushrooms growing but they would die quickly.
maybe i should apply Scotts DiseaseEX, and do sprinkler test coverage. |
07-18-2022, 10:22 AM | #1307 |
Rep 2,524
if mushrooms are growing, you are getting fungus on your lawn. you need to adjust your watering schedule so you arent overwatering during cool/dark times. give your entire lawn a good fungicide treatment.
nyalpine907433.00 |
07-18-2022, 10:46 AM | #1308 |
Rep 11,843
i already change time of watering to 7:30am and Mon, Wed, Fri & Su
07-23-2022, 08:46 AM | #1309 |
Rep 2,671
Hey Yard Freaks!
We are actively renovating our backyard - new walk way, shrubs, lights, pergola, sod etc…. My question is - we had new st augustine laid down on July 11th. It has rained a lot and a neighbor sprayed his companies bacteria product which makes the sod take root quicker and deeper. When I pull on a few blades it's clearly rooting well… Right now the new sod is probably 7 inches - how much longer should I wait to mow it - (at the highest setting of course)? |
07-23-2022, 10:44 AM | #1310 |
Rep 1,913
Drives: Here and There
My first mow when I redid the whole yard was pretty much right at three weeks after it was laid.
floridaorange10163.00 |
07-23-2022, 12:09 PM | #1311 | |
Rep 4,821
07-23-2022, 12:44 PM | #1312 | |
Rep 1,543
- Jeff
bosstones' flickr |
07-23-2022, 01:02 PM | #1313 |
Rep 2,671
Push mower - not even self propelled. I'm gonna let the 3 weeks play out - as mentioned on here. The sod is guaranteed by the company that keeps our grass weedless. I'm just itching to mow it - it's so long.
07-23-2022, 01:16 PM | #1314 |
Rep 1,913
I bagged mine for the first few mows to avoid bogging down growth. Definitely a push - sod wasn't ready to get the beating from the John Deere for a little while.
07-29-2022, 08:07 PM | #1315 |
Rep 2,671
We have a nice thick mature Jasmin in our front yard that separates the road from the sidewalk. We sold the house next to us and they are building a new home there now. A work truck parked in front of our house (not legal to park on our side of the road) and the truck fumes from the exhaust killed a 3-4ft diameter area of our Jasmin - from green to crispy brown. Whats the best course of action? Cut out all of the brown and replant Jasmin I assume is the only option?
07-30-2022, 06:53 AM | #1316 |
Crusty Old Navy Chief
22420
Rep 1,696
Drives: 2022 X3 M40i, 1983 911SC
07-30-2022, 07:59 AM | #1317 | |
Rep 1,543
- Jeff
bosstones' flickr |
07-30-2022, 08:25 AM | #1318 |
Rep 2,671
The exhaust roasted it so good there's a hole surrounded by dead jasmin - I had a photo up but the quality was bad, I'll post another here soon with my good camera. The realtor reached out to developer....
08-05-2022, 08:28 AM | #1319 |
Rep 1,543
I guess the fines started getting painful enough for the adjacent lot owner to finally contract someone to 'trim' their weeds to within regulation.
- Jeff
bosstones' flickr |
JJ 911SC22420.00 |
09-08-2022, 10:57 AM | #1320 |
Rep 11,843
lawn is getting a little better.
my landscaper just put down fertilizer. he discover lumps on my lawn, tunnel shapes and thinks i might have vole or mole... how do i get rid of it?? |
