      05-02-2022, 07:53 PM   #23
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
There are two type of valve actuators. The pre-lci exhaust had a vacuum unit to open the valve. the later units are electronic actuators. The vacuum units just need vacuum applied to actuate. You can use a solenoid valve routed to a vacuum source. The later units require a controller. The positioning is done using Pulse Width Modulation to change the position of the valve.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      05-03-2022, 12:40 PM   #24
RJV3
Customize Everything!
Drives: 17 F06 Gran Coupe/ 16 F10 535
Thanks for the clarification. So since I have an LCI, the only way to retain valve function and run and aftermarket exhaust is to get a valved exhaust system with valve controller? Based on your explanation, I assume I cannot use the m6 mufflers and salvage the valve function because my LCI 640 uses a seperate controller to actuate the valves. Is my understanding correct?
      05-06-2022, 08:30 PM   #25
arucano
arucano's Avatar
Not speaking from experience, but if you presently have electronic flaps, you should be able to use the electronic flaps of a different model with the same controller. The point is whether you are maintaining the same flap "motors" (vacuum or electronic). As far as the mufler swap, there were some discussion a while back on what saps are possible.
      03-20-2023, 05:27 PM   #26
Chaos236
Chaos236's Avatar
209
My 17 604 GC has a very simple to zip tie up(big zip tie) to hold open the flap right behind the tip.
      04-25-2023, 07:31 PM   #27
niksha87
Drives: bmw X6
Can you please share some picture how it looks and how you did it?
I have 17 640 GC
Thanks
