06-30-2020, 06:42 AM | #375 |
Rep 2,271
Finished the other side....
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
itzjoker149.50 |
06-30-2020, 07:43 AM | #376 |
Rep 289
06-30-2020, 08:09 AM | #377 |
Rep 2,026
got locking nut off front wheel,,was proper stuck,,ended up havng to put weld on it then putting a bolt removal socket on the weld,,the type that screw on the weld etc,now my slow puncture is fixed,,had a nail in it.
07-01-2020, 10:54 AM | #379 |
Rep 242
Painted my front calipers sublime green. Will get some nicer shots once I finish the rears. Needed to order a second can as these calipers are huge and I did not have enough left over for the rears.
Decided I wanted something completely different from the normal red/blue. Looking for some decals but not sure which to get. Not sure to even put decals on or not. Thoughts? |
07-01-2020, 03:00 PM | #380 | |
Rep 2,271
Decals would finish it off nicely. My opinion is go with a black M badge decal rather then white as the black would contrast better on lighter colours such as green and yellow etc.
IG: project540ix
07-02-2020, 03:56 AM | #381 |
Rep 131
07-02-2020, 05:22 AM | #382 | |
Rep 2,271
These are 20mm ones mate.
IG: project540ix
07-02-2020, 07:00 PM | #384 | |
Rep 2,271
Much appreciated Hoping to get the lower grills painted gloss black this weekend if the weather is good!
IG: project540ix
07-03-2020, 03:07 AM | #385 |
Rep 21
That will look good, we had an Audi estate a few years ago and I painted the grill gloss black rather than change it and I thought it looked great
Hoping to have my kidney grills painted in the next week or 2 and I've a splitter and some skirts ordered. Watching yours progress has inspired me to get stuck in again lol |
Junebug851615.00 |
07-03-2020, 04:19 AM | #386 | |
Rep 2,271
looking forward to seeing the end result and your pictures
IG: project540ix
07-03-2020, 04:30 PM | #387 |
Rep 286
oil service done at dealer. however normally it says on the reciept which grade oil they used i even checked an oil receipt and it had 0w30 on it, but this time just had drum LL 04. was curious because on the castrol website oil finder no longer shows 0w30 for my car instead 5w30 m is the prefferered option now. i know bmw stopped using castrol but the oil grade changed as well?
07-03-2020, 09:39 PM | #388 | |
Rep 285
07-04-2020, 08:43 AM | #389 |
Rep 100
Drives: 2013 650iX vert, 2017 Corvette
Had mine done at the dealership last week, so I went back and looking at the invoice it just said "BMW Twinpower Turbo" Quan 10. ???
07-04-2020, 11:26 AM | #390 | |
Rep 7,468
You can read about that at this link: https://www.shell.com/business-custo...-supplier.html Also, there are multiple recommended oil viscosities for the N63/N63TU/N63TU2 engines which can be found on the TIS website: https://www.newtis.info/tisv2/a/en/f...enance/1PSryV8 At the link above to the oil chart...you’ll see that the n63 engine variants have an LL-01 and/or LL-04 recommendations. It appears from the chart (if you click on the enclosure 5 & enclosure 6...that the BMW branded LL-01 oil viscosity recommendation is a 0w30 and the BMW LL-04 oil viscosity recommendation is a 5w30 oil viscosity...and either one can be used. And the LL-04 (enclosure 6) also lists multiple brand name oils that range from 0w30/0w40/5w30/5w40 Hope this helps settle some of your questions/insecurities about the oil viscosity used. EDIT 1: Oh H3LL ...temporarily disregard what I wrote above...I just noticed that you have a 640d and you’re not in North America. We didn’t get that model here and I made incorrect assumptions. Sorry...I’ll recheck what I wrote in case there are differences.EDIT 2: It appears the N57 engine used in the 640d in Europe should refer to LL-04 enclosure 6 at the link to the TIS website...and if you click that link it reveals that the LL-04 BMW branded oil for Europe can either be 0w30 or 5w30. And if you scroll down, it also lists multiple recommended brand names and the oil viscosity BMW recommends for that brand oil.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-04-2020 at 11:48 AM.. |
07-04-2020, 12:21 PM | #392 | |
Rep 286
07-04-2020, 03:21 PM | #393 |
Rep 289
Gave her some attention
sixfiftyay45.50 Junebug851615.00 |
07-04-2020, 03:41 PM | #394 |
Rep 2,271
Looks ace
I like those side splitter blades!
IG: project540ix
itzjoker149.50 |
