      01-06-2020, 08:39 PM   #1
burkhacs
Drives: 2022 M240i - TNM Shadowline
Bootmod3 Version 2.0 - N63
Has anyone flashed to the new bootmod3 2.0? I am curious what tweaks they made and if it is worth the effort. I also definitely do not want to flash to the new version if it makes the exhaust sound like a machine gun.
      01-06-2020, 10:03 PM   #2
E92TTCoupe
Drives: x335i/x550i/x640i/x540i/c750i
The BM3 lets you custom the exhaust sound. I believe the updates target more like the boost and software aspect of it if I知 not mistaken.
burkhacs126.00
      01-06-2020, 11:39 PM   #3
board57796
Drives: 2015 650i Gran Coupe
Good to know. I recently bought the BM3 tune and I知 glad I won稚 have to have the machine gun exhaust with it!
      01-07-2020, 12:19 AM   #4
E92TTCoupe
Lol definitely not. You値l enjoy the tune for sure and the exhaust you won稚 hear none of that not unless you wanted to. Enjoy.
burkhacs126.00
      01-07-2020, 12:01 PM   #5
burkhacs
Where can you customize that? The options I have in Map config are: Max cooling mode, cold start (cat heating), cold start RPM, pre-throttle TMAP sensor, Manifold TMAP sensor, Exhaust flap (sport), speed limiter (VMAX), Catalytic Monitors (CEL), and Boost by Gear (% reduction).
      01-07-2020, 01:14 PM   #6
AccordTR
AccordTR's Avatar
It's a non burble tune so no machine gun exhaust. I'm running it. It's got advanced ignition timing and better turbo output. It's definitely a power gain over version 4.0. You must have the older dme module as your map is 2.0 you mentioned. The newer dme is now version 5.0.
M Sports Edition
Carbon Wing
Carbon Front Splitters
Carbon Rear Diffuser
Carbon Grilles
CPG intakes
Arm catless downpipes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
burkhacs126.00
      01-09-2020, 11:29 AM   #7
burkhacs
Flashed mine last night, rider seems a bit smoother and has more power or at least a smoother band.... Could be placebo though!
      01-09-2020, 09:17 PM   #8
board57796
Did you do it yourself? Was it pretty easy? I知 scared to turn my car into a brick.
      01-10-2020, 08:31 PM   #9
AccordTR
AccordTR's Avatar
Did you do it yourself? Was it pretty easy? I’m scared to turn my car into a brick.
Ridiculously easy. I would recommend you drive the car for a bit to charge the battery up. Then pop the hood and use the terminals to hook up a decent battery charger. The first flash takes a little longer as it unlocks your dme and flashes the tune. If your car battery dies during the flash it's kinda a pain to reset it. After the first time it's very quick to flash tunes. Keep ignition on, keep the climate and radio off, close the door and buckle your seatbelt. Seatbelt on keeps the dme from falling asleep.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      01-10-2020, 09:10 PM   #10
board57796
Thanks for the tips! I知 gonna try tomorrow I think.
      01-14-2020, 02:30 PM   #11
burkhacs
Maybe Im a risk taker but I dont bother hooking it up electrically or anything. Lights, radio, ac, etc off and thats about it. Flash takes no time at all so Im never worried - especially with that RV battery in the trunk.
Looks like you posted a few days ago, how did it go and what do you think?
      01-14-2020, 02:36 PM   #12
board57796
Went well! I wasn稚 prepared for all the warnings to pop up during it so that made me a little nervous but I just assumed it was part of the process. It was my first time and I致e heard subsequent flashes go quicker.
I like it a lot. It痴 still docile in non-Sport, around town driving, but when it痴 in Sport or the boost has built up, its like a rocket. I smile every time I pin it.
Just realized you池e also in Colorado.
      01-14-2020, 05:06 PM   #13
AccordTR
AccordTR's Avatar
Thanks for the tips! I’m gonna try tomorrow I think.
Seen many cars die mid flash on the first unlock. You'd be surprised how much power dme writing takes.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      01-16-2020, 09:02 AM   #14
board57796
Yeah I’m definitely not loving my Boodmod3 anymore right now. Last night hit the gas on the highway and got drivetrain malfunction, flashing check engine light, car barely made it home and it’s still the same today. I have a “super knock” code showing in the Bootmod3 information. Wishing I hadn’t installed this tune now, the car was running great on a practically rebuilt motor before this.
      01-16-2020, 03:01 PM   #15
mrjsmith88
mrjsmith88's Avatar
151
Drives: 2017 BMW X5M
2017 BMW M3  [9.50]
Yeah I'm definitely not loving my Boodmod3 anymore right now. Last night hit the gas on the highway and got drivetrain malfunction, flashing check engine light, car barely made it home and it's still the same today. I have a "super knock" code showing in the Bootmod3 information. Wishing I hadn't installed this tune now, the car was running great on a practically rebuilt motor before this.
Not the bootmod3 the engine is not ready for anymore boost than it comes wit Unless u changing up pistons and rods engine is TRASH LOL
      01-16-2020, 07:21 PM   #16
AccordTR
AccordTR's Avatar
What codes did you throw? To completely blame bm3 is not fair. Post all the codes for your drivetrain malfunction. There are literally 10000s of cars on bm3.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      01-16-2020, 07:23 PM   #17
AccordTR
AccordTR's Avatar
What? You don't need to change any internals to run bm3, even in stage 2. It's already been proven the n63tu and the s63tu (m car) rods are the same. There are tons of guys, including me, running 600+ hp with stock internals.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      01-16-2020, 07:31 PM   #18
board57796
This is a sample as there were so many (some repeats), and I couldn’t scroll down on them in the browser for some reason. All injectors replaced by dealer in November.
152D08
14401C
140010
140310
140001
140301
140010
140310
140002
140302
140001
140301
140010
140310
140002
140302
140001
      01-16-2020, 09:04 PM   #19
AccordTR
AccordTR's Avatar
This is a sample as there were so many (some repeats), and I couldn't scroll down on them in the browser for some reason. All injectors replaced by dealer in November.
152D08
14401C
140010
140310
140001
140301
140010
140310
140002
140302
140001
140301
140010
140310
140002
140302
140001
First question is always when we're your plugs and/or coils replaced? Bm3 tends to find misfires very quick on older plugs especially.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      01-16-2020, 09:57 PM   #20
board57796
Not sure. I値l try swapping the coil and plug to another cylinder and see if the fault moves.
      01-17-2020, 11:09 AM   #21
mrjsmith88
mrjsmith88's Avatar
151
2017 BMW M3  [9.50]
Didn't say need lol said the engine is trash
      01-17-2020, 04:51 PM   #22
AccordTR
AccordTR's Avatar
Not sure. I’ll try swapping the coil and plug to another cylinder and see if the fault moves.
Awesome. Keep me posted. Try to help you out.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
