      08-18-2019, 02:50 PM   #133
vk535i
vk535i's Avatar
Drives: play genre classic rock
worked great ... thank you much!!!
      08-20-2019, 07:34 PM   #134
Slimm2.0
Slimm2.0's Avatar
Drives: F13
1. Is this the new updates Navigation map??
2. I have my car coded for extra goodies, like top down with the remote for example and etc..
3. If i update it, will my codes be deleted??
      08-21-2019, 11:15 AM   #135
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Glad to hear. No problem!
1. Yes. its the latest available for NEXT
2. I coded my car as well
3. No. Does not affect coding or tunes. You will need an FSC code to install the map unless you purchased a lifetime code in the past
      08-23-2019, 04:16 PM   #136
jsc1205
Drives: BMW x5
BadSeed - I have downloaded the files from your first post, unzipped them to a USB drive and for some reason when I go to my 2015 x5, nothing happens. Nothing pops up on the screen to update the navigation at all. I have a lifetime FSC due to a purchase I made awhile back directly from BMW.
So what am I doing wrong?
      08-23-2019, 05:04 PM   #137
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
1. You are 100% sure you have NBT & not NBT EVO?
2. The file system of your USB drive is FAT32?
If not, you can use this app to format it to FAT32
http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
3. You have the following files\folders in the root of the flash drive?
config.nfm
NBT_NANT_111184.3.112.pkg
NBT_NANT_111184.3.112.pkg.sig
Folder 1
Folder 2
Folder 3
Folder 4
4. Some cars have 2 USB ports but only one can be used to load maps\music. You'll need to figure out which one you need to use
      08-23-2019, 05:41 PM   #138
jsc1205
Drives: BMW x5
config.nfm
Folder 1
Folder 2
Folder 3
Folder 4
I'm pretty sure its the NBT one. When I go to map version on the car it says NBT not NBT EVO. Using info guide from Bimmer-tech.net since its a 2015 x5 it checks as being the NBT one.
Yes, the format of the USB is FAT32. The link you provided is the one I used to format the drive to FAT32
Yes, those files/folders are under the main folder for the map update.
The only USB port in the car is in the arm rest.
      08-23-2019, 05:55 PM   #139
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
https://f15.bimmerpost.com/forums/sh....php?t=1510490
Did you use the USB port in the center console?
On the USB drive, when you open it in File Explorer, you immediately see the files & folders or are they all inside another folder?
Not sure what else it could be. Do you have another USB drive to use?
      08-23-2019, 06:06 PM   #140
jsc1205
Drives: BMW x5
Figured it out. I had to move all the files/folders out of the folder it was unzipped to. Now that the car is recognizing it as an update, its now asking me for an FSC code! Any way to get this without paying for another?? I know I purchased a lifetime one a couple of years ago.
      08-23-2019, 06:25 PM   #141
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
The only way is to use an ENET cable & ESYS application to generate a DE.FSC file. Instructions are in the 1st post. Whoever created the FSC code you purchased clearly didn't set it as a lifetime code.
      08-24-2019, 09:52 PM   #142
Sotameyers
Drives: BMW 428i
Can I get the link please!!
      08-26-2019, 08:37 PM   #143
jlzzzz
Drives: 2017 X1
Does anyone know where can i find North America ROUTE 2020-1? Many thanks.
      08-28-2019, 12:25 PM   #144
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Its in the 1st post
https://www.6post.com/forums/showpos...31&postcount=1
      09-09-2019, 07:30 AM   #145
alboko177
Drives: 2016 BMW 640i GC
Could those maps be used to update NBT EVO? If not, then how to update maps for EVOs?
My 2016 640i seems to have NBT NEO v4. See the screenshot:
Thank you!
      09-09-2019, 07:35 AM   #146
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Thank you!
Screenshot shows NEXT Map, meaning NBT, not EVO map for NBT2 ID4/5/6.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
BadSeed158.00
      09-10-2019, 09:34 AM   #147
alboko177
I guess, you are right. The car has recognized uploaded 2020-1 NEXT maps from the USB and asked for FCS code.
I bought a lifetime code on eBay for $10 to avoid e-sys hassle this time.
The update took about a couple of hours from USB-3 drive.
BTW, I've used 256GB USB-3 drive formatted as FAT32 on Mac - worked nicely. Make sure to clean up all those hidden files if you do the same.
Thanks for helping!
      09-22-2019, 02:22 AM   #148
Alex2x3
Drives: F80 M3 ZCP(YMB)|24 X5M60i(BRG)
Thanks for helping!
Do you mind sharing who you bought the code from? So many sellers on Ebay, would be nice to know a legit one especially for 10 bucks!
      12-07-2019, 05:24 AM   #149
kwesie
Drives: BMW 640d F13
Does anyone know where can I find maps for Europe 2020-1?
      12-12-2019, 03:27 PM   #150
alexroet
Drives: BMW 2015 X3
Thanks for helping!
What do you mean "clean up those hidden files"? I'm a mac user and am using a FAT32 drive I've used before for updates, but this time nothing is happening when I plug it in.
      02-25-2020, 09:21 AM   #151
jackliu0527
Drives: BMW 650iXdrive GC
how to load the map if i have CIC?
      02-29-2020, 06:55 PM   #152
burkhacs
Drives: 2022 M240i - TNM Shadowline
Looking for same answer
2013 650i GC
      03-16-2020, 07:02 PM   #153
gster335
Drives: 2015 335i M Sport
Hi all im a f30 owner so i know im in the wrong place but just wanted to say thanks nonetheless for this amazing guide which worked perfectly for my car and just a few things id like to add.
-32gb hard drive is sufficient, first tried with macbook pro to download map but car wasnt recognizing so i reformatted the usb again to fat32 and then redownloaded map to usb from PC this time and it worked like a charm.
-fsc code was generated beautiful by jaeger app
      03-18-2020, 03:10 PM   #154
dpmarius
Drives: 2013 BMW 530D
South Africa Maps
Hey Guys Can anyone assist with south Africa maps?
