01-08-2022, 09:06 PM | #23 | |
I'm Batman!
3948
Rep 1,477
Keep in mind I'd pick the M5 over the Plaid any day, a friend has a Plaid and we rag on him every day with our shitty slow ICE cars.
S55, 2JZ, M48.00 |
01-08-2022, 11:19 PM | #24 | |
Rep 3,468
You might be in for a....shock.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
01-09-2022, 05:41 AM | #25 |
#buildnotbought
10847
Rep 4,892
During TF the Nordschleife isn't a racetrack but a tollroad where normal trafficrules apply.
When there's a trackday at the Nordschleife it's normal that a helmet is mandatory. That said this strange brakebehaviour of the plaid looks like it could also happen on autobahn speeds; having to make an emergency stop at ~230kph. Interesting that they can truely recreate this problem.
AlexFL7836.00 |
01-21-2022, 11:55 AM | #26 |
Rep 997
I know that this forum is anti-Tesla and "haters gonna hate" etc... But are Tesla brakes really that bad? I was looking at the recent Car-and-Driver review of the new Turbo S with Lightweight Package and I noticed that 100-0 MPH braking is only 5 ft better than Tesla Plaid. I know Porsche's braking is probably more predictable and can withstand the heat better and so on... but I expected a little better result from 1,300 lbs lighter the pinnacle of Porsche's engineering Turbo S... Something tells me that Plaid brakes issue is a little overhyped
01-21-2022, 12:19 PM | #27 | |
Rep 685
Drives: 06 Black Sapphire Z4MR
370Z suffers from an issue where repeated hard braking will cause the brakes to stop working (look up ice mode), and it was down to poor/lack of actual venting in the wheel well. Perhaps to reduce drag the Tesla doesn't allow as much air flow into the brake area than a conventional vehicle which in turn, doesn't allow the brakes to cool off adequately between hard stops. Just a thought FYI: The track used in the OP's video is from TMP, a local smaller track that is unfavorable to heavy and big cars, the two big brake zones are one after the other and neither are very long, and the infield is tight and favors smaller cars that can carry momentum, leaves very little area for any big car to shed heat in between laps.
Revolution of our Times
I will return to the track, one day. Last edited by kyriian; 01-21-2022 at 12:27 PM.. |
