      05-12-2020, 12:51 PM   #1
mikerx5
mikerx5's Avatar
461
Drives: 2014 F06, 2022 G06
Exhaust Tip Removal
Trying to dive in here - and it seems some have said there is a clamp to remove the 4 tips - nothing on mine with the stock exhaust and black comp tips.
Am I supposed to just whack these with a piece of wood and a mallet or is there some other process for the M6?
      05-12-2020, 03:19 PM   #2
xxTHIR13ENxx
Drives: M6 Gran Coupe
From what I was told, it's a bit of twist and pull.
I would assume some WD-40 behind each tip and wait 5-10 minutes would help.
What did you end up getting?
- Leo.
      05-12-2020, 04:13 PM   #3
KrazyKorean
KrazyKorean
KrazyKorean's Avatar
Drives: 2014 M6 Gran Coupe
I just took my rubber mallet and hit it from behind (TWSS) and they popped off. They are basically pressure fitted on.
      05-12-2020, 05:42 PM   #4
mikerx5
mikerx5's Avatar
461
Bingo - did the same - came off. THANK YOU!
      05-12-2020, 06:23 PM   #5
plm
Drives: M6 GC
Easiest way I've found is spray some WD40 in, let it dwell for a couple of minutes, and then pull with a pair of gloves on.
