04-08-2021, 03:47 AM | #1 |
Rep 36
BimmerCode features
Any recommendations for BimmerCode features? So far I've managed to do the following:
1) Turn off auto stop function 2) Close side mirrors upon lock 3 Remove warning startup message on Idrive 4) Remove seatbelt warnings. Thanks |
04-08-2021, 08:02 AM | #2 |
Rep 2,902
I made it so the doors unlock when I shut off the car so that I don't need to do the double handle pull to open the door, and I made it so that the iDrive shuts down when I open the door not when I lock the car, and I got rid of the empty screen when you scroll through functions with the button on the end of your turn signal stalk - average mpg, average mph, today's date, etc. One space is just blank. I got rid of that. And I did a couple goofy things like playing DVD movies while driving and having my side view cameras enabled at any speed.
KLONG6.00 |
04-09-2021, 04:39 PM | #4 |
Rep 7,449
If you open the app...you can open the demo mode (and go through each module) to see what coding parameters are available in each module.
You can then connect to the car, and go to those modules that contain things that YOU want to code that fit your personal preferences. If you have a battery charger...you could also hook it up to the engine bay terminals...then sit in the car connected to the app and your OBD adapter (or cables) and go through each module to see what can be coded and code to your hearts content without worrying about running the battery down. Depending on your model/model year and the modules and options you have...there are so many things that can be coded. I can't even remember everything that I've coded...the list below are the ones that come to mind without thinking hard about what's been done:
You can also peruse the coding forum threads to get an idea of the many things that can be coded...but when reading those threads...you need to take note of the model/model year etc that is being coded because you may not have the same set-up.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-09-2021 at 04:46 PM.. |
04-09-2021, 10:01 PM | #5 |
Rep 46
I code mine for the first time about an hour ago. Got rid of the camera warnings and turned on the option to fold the mirrors in on lock. Also got rid of the blank screen Opie55 mentioned.
04-10-2021, 06:58 AM | #6 |
Rep 284
I would like to add one more tid bit to Q's (as usual) informative post. If you latch the drivers seatbelt (as if you were driving), that will prevent the car from going dark.
04-10-2021, 07:12 PM | #10 |
Rep 46
Here’s what bummer code supports. I don’t see anything for blind spot. Did you accidentally deactivate via the button left of the steering wheel?
https://bimmercode.app/cars/f12/ |
04-10-2021, 11:16 PM | #11 | |
Rep 7,449
But as mentioned above...just check the panel below your light switch to see if you deactivated this option. On the f06/f12/f13...blind spot is activated/deactivated by an easy on/off switch & not buried in the safety intelligent switch or iDrive like in some other F chassis models...and it is not something you code on or off since there’s a dedicated switch for this feature if the car has this option. If the green LED on the far left of the switch is not illuminated...then just press the button on the far left to turn that feature back on.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-11-2021 at 07:23 AM.. |
KLONG6.00 |
04-11-2021, 07:25 AM | #13 |
Rep 7,449
Thanks for the update and glad it was something simple.
KLONG6.00 |
