      01-10-2020, 05:23 PM   #1
hart07
Drives: BMW 640i f13
640I F13 engine noise at stop
Hello everybody , i noticed an engine noise when the car is runing but at stop, i hear a kind of noise like belt or timing chain ( i don't know ) something is hangs .
My car is from 08/2012 and 99400 miles.
i did the classic services ( oil change, filters air and AC) need to bleed the brake now, but what i missed ?
i need to bleed the automatic gearbox drain , but my gearbox is ok and is not the problem.
its like a noise belt or timing chain perhaps .
the drive belt ?
Thanks for your help.
regards
      01-10-2020, 06:03 PM   #2
hart07
i can post a video for you to hear the noise.
      01-11-2020, 01:13 PM   #3
hart07
Need help
Thks
      01-11-2020, 03:43 PM   #4
hart07
https://youtu.be/eYQI1Cm98ds
This the YouTube link
      01-11-2020, 06:47 PM   #5
hart07
      01-11-2020, 08:48 PM   #6
e38740imd
Drives: 2016 640i
you are better of posting in the f30 forum in the n55 engine section. more knowledgeable people will be able to help diagnose the problem. people here usually take there cars to the dealer if anything arises
also it seems your oil filter gasket is leaking. i would recommend getting that repaired asap to prevent future damage
      01-11-2020, 09:18 PM   #7
hart07
You really think my oil filter gasket is leaking?
Why is possible
I will look better this one but sure there are some oil on the right side, perhaps old oil.
      01-30-2020, 06:53 PM   #8
hart07
oil filter housing gasket is leaking on my car or its perhaps a housing filter with too much torque when i changed my oil in june 2019.
i changed my oil filter and drain my oil in june 2019.
perhaps i torque too much my oil filter housing and result this leak ?
or its a classic issues with this oil filter housing gasket ?
thks
      01-31-2020, 02:19 PM   #9
e38740imd
Drives: 2016 640i
thks
how many miles are on this car> oil filter housing gasket will eventually leak from the inside.
only way it leaking from when you did the oil change would be if you didnt actually torque it down all the way.
if still have an other issues. again make a post here for expert adivice
https://f30.bimmerpost.com/forums/fo...play.php?f=421
      02-13-2020, 10:10 AM   #10
JP1906
Drives: '12 328i and '12 640i
I think it may be one of your pulleys and/or belt. My oil filter housing gasket was leaking (common occurrence with this engine) and oil leaked on my belts and pulley. Had the oil filter housing gasket changed, plus belts and pulley.
Edit: IIRC they replaced a pulley, belt tensioner and belts due to my oil filter housing gasket leaking onto them. From your video, it looks like oil housing gasket is leaking as well.
