      04-05-2021, 10:12 PM   #1
debauch
Drives: M6GC
Climate controls
Hi all. Need some help. This driving batty. Not luck on google nor in the manual.
When my kids adjust the climate settings in the rear (temp or fan speed) the driver side temp and fan speed also change. I canít find a way to decouple the rear and driver side zones. Sync is off.
Any ideas?
18M6GC
      04-05-2021, 10:34 PM   #2
premo
premo's Avatar
Drives: E92 M3, F13 M6
When my kids adjust the climate settings in the rear (temp or fan speed) the driver side temp and fan speed also change. I can’t find a way to decouple the rear and driver side zones. Sync is off.
Any ideas?
Download the "bmw drivers guide" app from app store. Its should have your owners maunal accessible from your phone. That might help you out.
      04-11-2021, 07:24 PM   #3
What happens if you go into SETTINGS ó-> CLIMATE & uncheck the rear climate box in iDrive?
BMW CCA Member #191509
debauch21.00
      04-11-2021, 09:54 PM   #4
debauch
Drives: M6GC
That turns off the rear controls. But they turn back on again when the kids press one of the rear climate buttons.
I did some testing. The rear fan speed button controls both rear and front fan speeds. For example, if I turn the driver fan speed all the way down (but not off) then turn the rear fan speed all the way up, the driver side fan speed increases up as well. Is that normal?
      04-12-2021, 12:04 AM   #5
brad850csi
Drives: 16 F13 M6 Comp
remove their hands
      04-12-2021, 11:53 PM   #6
debauch
Drives: M6GC
Originally Posted by brad850csi View Post
remove their hands
Theyíre my kids. I sort of like them. Plus who would wipe their behinds?
18M6GC
      04-13-2021, 12:31 AM   #7
brad850csi
Ok you've got me on the last point
      04-13-2021, 09:20 AM   #8
...For example, if I turn the driver fan speed all the way down (but not off) then turn the rear fan speed all the way up, the driver side fan speed increases up as well. Is that normal?
No...that is not normal operating parameters in either my f06 or f15. The rear controls do not change any of the settings on the front IHKA control panel.
Just to verify...has the car had any coding done to the HVAC system that may have given the rear HVAC system the same "SYNC" control that the front HVAC panel has?
      04-13-2021, 12:54 PM   #9
debauch
Drives: M6GC
Thatís a good question. I havenít coded the HVAC system but Iím not the first owner. I donít see HVAC sync options in bimmer code though. Might be under expert mode ... which Iíve avoided peaking into for obvious reasons. Thatís a good tip though. Iíll have to do some research.
18M6GC
      04-13-2021, 05:37 PM   #10
Based on some info from the TIS (see below)...the IHKA (front control panel) is a master controller...and if you have the rear HKA/FKA options...then they are "slaves". To me, that reads the rear HKA/FKA control panel should NOT have any affects on the front IHKA control panel since it is a slave and not a master controller. Something is either wrong or has been changed if you can control your front IHKA from the rear HKA/FKA:
debauch21.00
      04-13-2021, 09:28 PM   #11
debauch
Drives: M6GC
Wow. Thank you for the info. I dove through the bimmercode app (normal and expert modes) but didnít find anything that made sense to me. I donít code so didnít want to tinker around too much in there. The car has 4Nb 4-zone climate controls though so probably something is broken somewhere. Trip to the dealer for me!!
18M6GC
