07-23-2021, 11:30 AM | #1 |
Mad Fiddler
792
Rep 991
headlight washers
I don’t want the headlight washers to fire when I use the windshield washer, but lately they have been. Any suggestions? (2016 640i GC)
07-23-2021, 01:35 PM | #2 |
Rep 631
it can be coded out or you can disconnect the power to the headlight washer pump.
Frupal791.50 |
07-23-2021, 08:07 PM | #4 |
Rep 631
It is coded to clean the headlights every so many windshield washer cleanings. It can also be coded to never do it (which is what I have since we don't have to clean snow and ice off the headlights here) It can be set Active or non active. The number of squirts during headlight cleaning. Headlight blocking time. Time between pulses. There is also a speed above which it does not spray. Duration of spray.
You can code this using BimmerCode which is easy to use. There are other software packages that can do it as well be they require a little mode in depth knowledge.
07-24-2021, 07:45 AM | #6 | |
Mad Fiddler
792
Rep 991
07-24-2021, 12:37 PM | #7 |
Rep 7,475
The headlights (as mentioned above) get washed on an interval…AND…the headlights have to be ON in order for them to get washed.
If you haven’t done any coding…your headlamp washing system should work as described below:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-26-2021 at 10:04 AM.. |
07-25-2021, 06:27 AM | #8 |
Mad Fiddler
792
Rep 991
As always, a clear and complete answer! Thank you!
