      08-03-2019, 07:12 AM   #1
frazj
Drives: BMW 640d Coupe
Molykote D 96 lubricant alternative?
Hi guys
Newtis mentions "Molykote D 96" lubricant on several occasions. I have tried to source this online, but it is hugely expensive and can only be bought in large quantities.
Does anyone know of suitable alternative?
Thank you!
      08-03-2019, 09:53 AM   #2
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
What are you planning to use it for?
      08-03-2019, 01:18 PM   #3
arkie6
Drives: 2008 BMW 335i sedan
2008 BMW 335i  [0.00]
According to the Molykote D-96 technical datasheet, it is an air-curing dry film lubricant that is safe for paint and plastics. It is manufactured by Dow Corning.
A possible alternative that has similar properties and is readily available in small quantities would be DuPont Teflon Non-Stick Dry-Film Lubricant.
http://www.performancelubricantsusa....-lubricant.php
      08-16-2019, 09:05 AM   #4
frazj
Sorry for the delay in replying to this post.
I was interested in the lubricant as it is recommended in this procedure in newtis:
https://www.newtis.info/tisv2/a/en/f...f13/1VnXaeVVq8
      08-16-2019, 09:47 AM   #5
tracer bullet
I guess what I was really wondering was how important it was. If you were doing something like lubing main bearings before reinstalling a crankshaft you might want to follow recommended procedure carefully. If you're putting some grease between a spring and piece of squeaky foam in a seat, any close substitute would seem to be fine without worry.
Tags
grease, lubricant, molykote, newtis, tis
