11-29-2020, 03:19 PM | #2 | ||
Rep 99
As long as there hubcentric your good. And get a good high speed balance and torqued correctly.
M6 Daddy
GiftyM60.00 |
11-29-2020, 06:07 PM | #4 |
Rep 11
11-29-2020, 06:08 PM | #5 | |||
Rep 11
11-29-2020, 06:09 PM | #6 |
Rep 280
I think they were H & R
11-29-2020, 06:12 PM | #7 |
Rep 11
11-29-2020, 07:47 PM | #8 |
Rep 582
If you dont mind spending a little extra for spacers definitely go with Future classic by IND.you will have zero problems
https://ind-distribution.com/collect...r-kit-14mm-lug
GiftyM60.00 |
11-29-2020, 07:53 PM | #9 | |
Rep 11
11-29-2020, 08:03 PM | #10 |
Rep 582
I went with 10mm in all 4 corners,im running stock 265 front tires and 305 in the rear the fitment is pretty damn good no rubbing,I might even try a 315 r888 in the rear with the 10mm spacers might just make it
A lot of guys run 10 front 12 rear but at that point you can only run stock width tire is a 295,If you want to run a 305 it might rub
GiftyM60.00 |
11-29-2020, 08:07 PM | #11 | |
Rep 11
I heard 10 mm in the front vibrates as it doesn't clear the hub specially models prior to 2016 |
11-30-2020, 03:51 AM | #12 |
Rep 307
Not sure if spacers have any negative performance or hardware impact to the bolts at stop and go with high accelerations however I imagine because spacers just sit between hardware these have minuet but real play and tolerance that can damage the wheel bolts...
The look and stance is excellent nonetheless... I would also say the grime from the road will have more area to clean then having the wheels in their stock placement under the fender 100%... paint damage overtime on the lower door sides may or may not be a thing but just worth considering. Great pics |
11-30-2020, 04:33 PM | #13 | |
Rep 582
I have Carbon side skirts that protect my rockers from rock chips |
GiftyM60.00 |
12-02-2020, 05:36 PM | #17 | |
Rep 280
12-03-2020, 02:19 AM | #18 | ||
Rep 11
12-09-2020, 10:58 PM | #20 |
Rep 11
